General For Sale Section Sell all your General, non Fit related items here. MUST HAVE 20 POSTS
FS: Wilwood 'Q' Compound Race Brake Pads
Old May 25, 2009 | 01:03 AM
Sid 6.7's Avatar
Why so serious?
Wilwood Q Compound Racing Brake Pads ** New in Box **:eBay Motors (item 280348814067 end time Jun-21-09 00:44:59 PDT)
You are bidding on a complete set of disk brake pads from Wilwood. These pads are made for, and will only fit Wilwood calipers
These pads will fit the following calipers from Wilwood:
Billet Narrow Superlite 4
Billet Narrow Superlite 4-Race
Billet Narrow Superlite 6 Lug Mount
Billet Narrow Superlite 6 Radial Mount
Forged Narrow Superlite
These pads will NOT fit OEM calipers of any model vehicle.They only fit Wilwood Billet Narrow Superlite 4 and 6 Piston calipers.
In the box you will find a total of four (4) separate pads, two (2) pads for each caliper.
They are the 'Q' race compound from Wilwood. They are perfect for street use and some track use. They are the most aggressive pad that Wilwood produces that have the least amount of noise and dust.
So if you want a super aggressive bite to your brakes, but you don't want them to be as loud as other race pads, and you don't want to have a massive dust build-up on your beautiful wheels, then this pad compound is for you!
These pads are brand new in the box and have never been installed, used, or even mounted into a set of calipers.
Bid with confidence. Although I am providing no warranty expressed or implied, there is a seven (7) day money back satisfaction guarantee on these pads, minus any shipping costs. You can return them for a refund, minus shipping costs, for any reason within seven 7 days of receipt, granted that they have not been installed or used, and are returned in the exact same condition that they were received in.
Here is a link to the specs on these brake pads: Wilwood Brake Specs
Product Number:15Q-6828K
Pad Number :7416
PolyMatrix "Q":
Characteristics & Applications
*Enhanced friction ceramic formula features the lowest noise and dust properties available from a performance compound pad.
*Improved friction over OE replacement pad compounds with smooth engagement, long service life, increased fade resistance, and quick recovery time.
*Best compound for specialized application aluminum rotors, and compatible with all vented iron rotors.
*Sprint cars with aluminum rotors.
*Disc brake conversions on street rods, muscle cars, custom show cars, and all moderate performance applications where low noise and dust are important.
Performance Characteristics
* Medium friction, smooth engagement, low abrasion on iron rotors.
* Flat torque curve. Can be used with aluminum rotors on Sprint Car applications.
* Low wear rate at low to medium temperatures
When choosing a pad compound, keep this information in mind:
Temperature range and overall friction value are the primary considerations for pad selection. The pads must be capable of maintaining the proper amount of friction for stopping power within the temperatures that will be realized on the track during the event. Then, overall wear rate must be considered. For most asphalt and road race applications, compounds in the high temperature ranges over 1000°F range are usually necessary. Dirt track, drag race, and street performance applications usually operate at temperatures between 500° and 1000°F. Keep in mind that these are general ranges, and not absolute values. Many factors and unforeseen influences can affect brake temperatures. The best indicator for pad selection will always be on track performance. If pad fade (friction loss) due to overheating occurs, then improved cooling, a heavier rotor, or a higher temperature range pad may all become necessary.
This is what the caliper looks like:(Please note, these calipers are not part of this auction, only the racing pads are being sold here. This photo is merely for illustrative purposes.)
Here are the photos of the actual product you will receive after winning the auction:
Old May 28, 2009 | 01:08 AM
dewthedew's Avatar
is there a willwood brake kit for the fit that would fit this?
Sid 6.7
Jun 27, 2009 11:51 PM
Sid 6.7
Off Topic Discussion
Aug 3, 2008 09:02 PM
