Civic Rims on A Fit Sport
Old Jul 14, 2009 | 08:20 PM
novascroller's Avatar
Will a set of 14" rims from a '04 Civic fit on a Fit sport? i have studded winter tires mounted on them and i'd like to keep them if they would fit on the Sport. thanks.
Old Jul 15, 2009 | 06:39 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
yes all depending on tire size and offset.
give us some more info on your car.
is it stock lowered? size are the tires and offset?
Old Aug 7, 2009 | 11:45 AM
ok, so i won't be getting a sport but what i'm wondering if the winter tires that i have on my civic rims 18570R14 will fit on the DX or LX??
Old Aug 7, 2009 | 12:38 PM
Malice101's Avatar
Base steel wheels are 15"...so no...
Old Aug 7, 2009 | 12:54 PM
if the ratios matched pretty closely and the bolt pattern matches, what would be the difference?
Old Aug 7, 2009 | 01:08 PM
dela's Avatar
probably wont clear the calipers... but thats just a guess
Old Aug 7, 2009 | 01:29 PM
Malice101's Avatar
Your snow tires are made for 14" wheels...18570R14
The steel wheels on the base are 15"...
Old Aug 7, 2009 | 01:54 PM
my bad, i meant these tires are mounted on 14" rims already.
Old Aug 7, 2009 | 03:59 PM
dela's Avatar
if you have the wheels/tires already you can always test fit... easiest/best way to find out if it fits... lol
Old Aug 7, 2009 | 05:10 PM
GE8749EW's Avatar
Go here to check your size!
Tire Size Calculator - tire & wheel plus sizing
I checked your size to the Fit Sport (185/55/16)
Fit diameter is 24.01 inch and the 185/70/14 is 24.19 inch.
Your withen 3% so your good to go! As long as the caliper clears.
Old Aug 7, 2009 | 05:32 PM
excellent, thanks.
Old Aug 7, 2009 | 05:33 PM
GE8749EW's Avatar
excellent, thanks.
No problem!
Old Aug 7, 2009 | 05:35 PM
Interstate526's Avatar
you might need spacers so they will clear the calipers. I think i've read that 5mm spacers would do the trick.
EMC2
Oct 31, 2012 10:47 AM
skygrabber
Jan 21, 2009 07:19 PM
stendzme
Sep 22, 2008 02:50 PM
Quartz
Dec 9, 2007 03:55 PM
photofit
Dec 2, 2006 02:21 AM
