Fog light bulb types?
Old Apr 30, 2006 | 07:28 PM
fitjunkie's Avatar
flip'n through the whole book and still can't find what type of bulbs are used for the fog light...
Old Apr 30, 2006 | 07:31 PM
ezekielwhore's Avatar
H11 my friend.
Old Apr 30, 2006 | 07:40 PM
fitjunkie's Avatar
did you swap your factory bulb out?? those JDM yellow is HOT!!
Old Apr 30, 2006 | 07:56 PM
Tomh's Avatar
Senior Member
i had ordered some H11 from luminics, over a week ago, and still ahven't gotten them yet, and i should have gotten them last wensday, now i'm getting a little ticked at luminics.
Old Apr 30, 2006 | 08:59 PM
sillypuddy's Avatar
Someone that Posts too much
I got H11 yellows .. it pwns
-joe
Old Apr 30, 2006 | 09:02 PM
dougiepants's Avatar
Avid FitFreak Poster
Great to know for sure...
Old Apr 30, 2006 | 09:06 PM
sillypuddy's Avatar
i got them locally.. if you are swapping them out, change your headlights at the same time, since you will have to take out hte fender to do either one..
-joe
Old Apr 30, 2006 | 09:39 PM
fitjunkie's Avatar
-joe
How hard is it to take out the headlight bulbs?? Doesn't look too complicated...
Old Apr 30, 2006 | 09:43 PM
sillypuddy's Avatar
wait until you do it
you will end up with scrapes up and down your arm if you are not 100lb skinny azz guy
there is like no space up there and you have to do it by feel.. you can't ever see the bulb
-joe
Old Apr 30, 2006 | 10:15 PM
fshwcrs's Avatar
Old Apr 30, 2006 | 10:31 PM
uh changing the foglights are super easy. not hard at all. i dunno bout taking the fender out. thats weird. for the foglights all you need is a screwdriver.
Old Apr 30, 2006 | 10:44 PM
Tomh's Avatar
Senior Member
all i did when i put my HID's in was jack up the car, take out 2 inner fender clips and tie the inner fender liner back, which gave plenty enough room to change around everything.
Old Apr 30, 2006 | 10:52 PM
Mugen_Dom's Avatar
The fog bulbs are changed by taking the whole foglight out from the front.
The headlight bulbs are changed by going thru the fender.
Let us know how the luminics bulbs are. I'm looking to get a rich yellow colour a la the 1st Gen TL / 2nd Gen Legend fogs
Old Apr 30, 2006 | 11:34 PM
piaa > luminics
Old Apr 30, 2006 | 11:35 PM
Tomh's Avatar
Senior Member
so your saying Piaa is better then Luminics, i think PIAA's are what a 110 watt bulb, but what is the luminics.
Old Apr 30, 2006 | 11:57 PM
fitjunkie's Avatar
I ordered some PIAA GTX for the headlight and probably opt for luminics JDM yellow for the fog soon...the OEM color is so not working for me..but PIAA are some expensive shiet.
Old May 1, 2006 | 12:30 AM
the ones on my fit are Piaa Ion Yellows.
Old May 1, 2006 | 08:37 AM
sillypuddy's Avatar
i didn't need to take out the fog itself, you can actually see the back of the fog when you take out the wheel fender liner. the headlight is high above and you have to reach up to get to it
I believe the manual says to to take out the fender for both lights.
I rather not fock up the aiming of the fogs by taking it out the front
-joe
Old May 1, 2006 | 09:35 PM
-joe
you wont mess up the aiming of the foglight. why go through the trouble of taking off the fender when it only takes one screw to take off the foglight?
Old May 1, 2006 | 10:10 PM
sillypuddy's Avatar
where is the screw that you take out? i will probably end up doing that next time then
-joe
