Piston slap anyone?
Old Dec 1, 2009 | 08:36 PM
willy65000's Avatar
Piston slap anyone?
I posted a thread a while back about this issue and I'd like to know if anyone else has noticed this. My car suffers from piston slap and I notice it if I start my car and idle it for a minute or two. After driving for a while and fully warming the engine it goes away.
Old Dec 1, 2009 | 08:50 PM
Texas Coyote's Avatar
I've heard piston slap in old worn out big bore air cooled motorcycles and VWs but not on anything water cooled except some ancient farm tractors....`Is your engine using an excessive amount of oil?.... I have noticed that my engine is making some unusual noises since the weather has gotten cool.. What I am hearing is coming from the intake inlet and goes away as the engine warms and the RPMs drop.
Old Dec 1, 2009 | 09:47 PM
willy65000's Avatar
The noise isn't coming from the top end like the sound that valves make on a cold honda engine. It's in the bottom end of the motor and is a deeper sound. Other than this noise it runs fine, gets good mileage and doesn't burn any oil to speak of.
Old Dec 1, 2009 | 10:05 PM
If you remove the top of your air cleaner box and remove the filter you can hear the sound get louder if it is what I am hearing..... It sounds mechanical and it might be from the throttle control valve on mine... Like yours it it will gradually quieten down and sounds fine when the cold engine light goes of and the idle RPM drops.... It sounds very much like piston slap.
Old Dec 2, 2009 | 01:36 AM
5speedwonder's Avatar
ford lightnings were infamous for severe piston slap in the first few production years
i haven't noticed any unusual noises at all on my fit 26k miles goin strong
Old Dec 2, 2009 | 02:34 AM
JDMxGE8's Avatar
I wonder if your piston rings seated properly.
Old Aug 11, 2011 | 12:46 PM
DOHCtor's Avatar
My engine is experiencing piston slap too, except i wont hear it when cold at 1200 - 1300rpm but will definitely hear it when hot at 850Rpm.... It sounds a lot like my old Neon! Except the Fit is 10 years younger and have a lot less milleage and was always serviced with AMSoil ou Red Line oils! I guess it will recieve the Wiseco treatement as it's out of warranty now...
Marko!!
Old Aug 11, 2011 | 01:28 PM
phenoyz's Avatar
DAMN I thought it was " Pistol Slap" ...my bad
Old Aug 20, 2011 | 03:54 AM
DOHCtor's Avatar
Boooeurns!!! :P
Marko!
ck42
Jan 4, 2020 04:35 PM
Ryan2020
Jan 29, 2013 11:03 AM
willy65000
Nov 19, 2011 05:25 PM
Kwonye
Jul 12, 2010 07:11 AM
Drewski
Oct 6, 2008 02:08 AM
