Abs light
Old Jan 4, 2010 | 07:06 PM
123fit's Avatar
Abs light
We lowered my friends car and the abs light turned on when he left do you know what it could be. I checked the clips in the front and put them back.
Old Jan 4, 2010 | 07:37 PM
vinn's Avatar
well, it could be many things
axle, abs cable, i have no idea
Old Jan 4, 2010 | 07:39 PM
123fit's Avatar
The axel did pop out and we put it back could that set it off
Old Jan 4, 2010 | 10:05 PM
kingofpicklez's Avatar
that happened to me too, the guy said it was due to the sensor, but i don't know how to fix it
Old Jan 4, 2010 | 10:21 PM
123fit's Avatar
So its from dropping the axle I'm assuming
Old Jan 4, 2010 | 11:54 PM
my axle did pop out before, anyone have any suggestions?
Old Jan 5, 2010 | 12:14 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
if you never disconnected your abs lines when you were
lowering the vehicle, then most likely you stretched one
and don't know it.
Old Jan 5, 2010 | 12:27 AM
123fit's Avatar
They were disconnected where would I check if they were stretched and how do I reset the light cause we drove it today and it ran fine and stopped fine.
Old Jan 5, 2010 | 01:09 AM
by it ran fine and stopped fine, did you mean the abs worked? or do you mean regular driving and stopping was normal
Old Jan 5, 2010 | 01:21 AM
123fit's Avatar
Everything was fine like it was before. Its just the light.
Old Jan 5, 2010 | 12:53 PM
Virtual's Avatar
From your posts up until now... Your perception of this is questionable. I highly recommend that you back away from the tech aspect of your car and take it to someone competent.
Old Jan 6, 2010 | 12:57 AM
123fit's Avatar
Its not mine its my friends he gave me a ride after we put in and it was fine. But thanks anyways guys.
Old Jan 6, 2010 | 01:48 AM
thats what i'm planning on doing, once i'm back in the states. I just never got the chance to bring it into a shop
Old Jan 6, 2010 | 02:03 AM
doctordoom's Avatar
Supervillain
just making sure because there's lots of different people on these forums; so please don't be offended if this is elementary.
so you rode in it with your friend and you guys slammed the brakes down to check that the abs was working properly right?
Old Jan 8, 2010 | 10:36 PM
123fit's Avatar
Yeah we slammed on the brakes and it was fine do you know how to reset the light?
Old Jan 8, 2010 | 10:45 PM
niko3257's Avatar
so the abs worked? the pedal pulsated?
Old Jan 8, 2010 | 11:09 PM
123fit's Avatar
Yes you could feel the pedal pulsate
Old Jan 9, 2010 | 11:30 AM
niko3257's Avatar
sounds like u have a different problem or you
just need to rest the light. but definitely check
for codes before you reset it. so you at least
know a little about what caused the light.
Old Jan 9, 2010 | 02:56 PM
123fit's Avatar
Can you tell me how to reset it my uncle who is a mechanic checked it out but doesn't know how to reset it.
Old Jan 10, 2010 | 12:40 PM
niko3257's Avatar
the only way i know is by OBD scanner. which i have to look
up codes and reset them.
Now i'm not sure if you can just disconnect your battery and
it resets. it might work might not. i have read that some guys
did it just don't remember if it worked. remember to have
your radio code if you do this. maybe someone else will chime
in and let you know about the battery thing.
