Does coasting in neutral hurt anything?
Old May 18, 2006 | 11:42 AM
Mesaba's Avatar
I was wondering if coasting in neutral in a car with a manual transmission hurts anything - ignore the safety and legal issues.
Old May 18, 2006 | 11:43 AM
Jonniedee's Avatar
Clutch in or out?
Old May 18, 2006 | 11:47 AM
Mesaba's Avatar
Clutch out
Old May 18, 2006 | 11:50 AM
Jonniedee's Avatar
Question
Besides safety and legality - if the manual doesn't say no then why should it be an issue? Just more work for your brakes without the engine available to add slow down drag
Old May 18, 2006 | 12:08 PM
DRum's Avatar
Senior Member
It hurts nothing. I do it all the time on long hills and while approaching a stop.
Old May 18, 2006 | 12:13 PM
aziatiklover's Avatar
Master FitFreaker
doesn't hurt anything at all
Old May 18, 2006 | 12:52 PM
Paulo107's Avatar
just dont ride the clutch
Old May 18, 2006 | 01:38 PM
Occidio's Avatar
It doesn't do a thing with the clutch in or out.
Old May 18, 2006 | 02:22 PM
wyy183's Avatar
Coasting in neutral doesn't hurt the vehicle; however, in some states it is illegal.
You might want to check your local state's laws.
FWIW - I've been doing it for years, with no issues!
David
Old May 18, 2006 | 04:15 PM
xorbe's Avatar
I can't imaging how one could ever get in trouble for coasting in neutral... "I missed the gear" or whatnot...
Old May 18, 2006 | 04:25 PM
wyy183's Avatar
In Nevada:
NRS 484.459 Coasting prohibited. 1. The driver of any motor vehicle when traveling upon a downgrade shall not coast with the gears of such vehicle in neutral.
2. The driver of a commercial motor vehicle when traveling upon a downgrade shall not coast with the clutch disengaged.
(Added to NRS by 1957, 504)—(Substituted in revision for NRS 484.706)
In Minnesota:
169.39 Coasting.
(a) The driver of any motor vehicle when traveling upon a
neutral.
(b) The driver of a commercial motor vehicle when traveling
In Florida:
316.2024 Coasting prohibited.
I found references, in a quick search, about the same in Tennessee and Texas. This was just a quick search...
David
Old May 18, 2006 | 04:40 PM
GoFit's Avatar
Someone that Posts too much
wouldn't you rather coast in gear and engine break?
Old May 18, 2006 | 05:14 PM
DRum's Avatar
Senior Member
So how can anybody tell if you are coasting? Must be hard to enforce.
As an aside, a friend of mine was a highway patrolman for years in Wyoming, and he said that he clocked a semi at 130 coming down out of the mountains. The guy protested that the truck had a governor and could not go that fast.
Of course when the vehicle is in neutral coming down a 7 mile long 6% grade the governor is not a factor.
Old May 18, 2006 | 05:23 PM
wyy183's Avatar
Yeah, and if a buffalo steped out in front of it... there would be fur for miles!!!
Old May 18, 2006 | 08:07 PM
bitterspeak's Avatar
Seriously. The cop would need super sensitive hearing.
Old May 18, 2006 | 08:53 PM
Gordio's Avatar
I wonder why it's illegal in the first place.
Also, my bro says if you coast, it has to eat its own oil since you're not feeding the engine gasoline or something (he's saying it needs something, and will eat engine oil if you don't give it gasoline oil). I don't believe him, but anyone clear the light what he's talking about?
Old May 18, 2006 | 09:30 PM
Okietom's Avatar
If you are going down a steep grade it is unsafe to keep using your brake to do all of the braking. When your brakes get too hot they will fade and not work as good. If you keep using them after that they can catch fire and go comepletely out if the brake burns up. Engine braking down hill is a safety practice. Coasting in neutral would not be good at those times. Those laws are for safety.
Old May 18, 2006 | 09:44 PM
benfal2001's Avatar
Excuse my ignorance but I'm french and what's the meaning of coasting ?
thnks.
Old May 18, 2006 | 10:01 PM
Okietom's Avatar
benfal2001, coasting is when you use the inertia of the cars motion to keep it moving instead of using the engines power, gravity going down a hill can also be used to coast.
Old May 18, 2006 | 10:15 PM
benfal2001's Avatar
Okay! Thanks! I'll be sleeping less dumb. :-)
