hub bore question
Old Jun 11, 2010 | 01:26 AM
andyd's Avatar
hub bore question
i know our fits have a 54.1 mm hub bore...
my question is can i run a bigger hub bore such as 56.1mm?
I am assuming you could.
Old Jun 11, 2010 | 01:45 AM
danger69's Avatar
Yes you can. But with a larger hub bore it throws the wheel off from being centered. Thats what the hub bore adaptors are for. I have a set of wheels that are 74mm and I had to buy hub bore rings to reduce it.
Old Jun 11, 2010 | 02:51 AM
555sexydrive's Avatar
Yes just get some hub-centric rings like mentioned above. You could do without since it is just 2mm difference, but not sure why anyone would want to when a good quality ring will be about $20 for all 4 wheels. Hell maybe even cheaper than that stateside, I just purchased some directly from Rays here.
Old Jun 11, 2010 | 10:35 AM
andyd's Avatar
word, thats what i thought thanks for the info
Old Jun 12, 2010 | 02:49 PM
roflmayorga's Avatar
so you have to use rings when changing hb?
Old Jun 14, 2010 | 12:53 PM
DatFIT's Avatar
Most aftermarket wheels comes with hub rings.. good way to use them =]
Old Jun 14, 2010 | 01:24 PM
GD3_Wagoon's Avatar
i went to a machine shop and they made me a set of hub rings from scrap metal for $7
Old Jun 14, 2010 | 05:22 PM
LaoSiFu's Avatar
I think you are a bit confuse about it. Most aftermarket wheels bore sizes are NOT the same size are your hub bore. To fill in that gap you need to purchase a hubcentric rings where the inner part fits your hub bore (I don't know what the fit is) and the outer part of the rings fit your rims.
^Sorry I know I can explain better but I am eating finger foods and talking on the phone @ the same time
~Robert
Old Jun 14, 2010 | 05:45 PM
i understand, just read about a lot of people not using them, im gonna buy some if my wheels dont come with, what kind do you guys use, alum, poly, plastic, other
Old Jun 14, 2010 | 05:46 PM
also read that our fits are 56.1 not 54.1
Old Jun 14, 2010 | 05:51 PM
andyd's Avatar
hmm, i read different. Anyone know for sure?
Old Jun 14, 2010 | 05:57 PM
GD3_Wagoon's Avatar
the Fit's hub bore is 56.1mm
rocketberger
Oct 16, 2012 10:09 PM
fitisno
Apr 23, 2011 09:51 PM
Tofuik
Sep 11, 2009 01:56 PM
CSquared
Jul 11, 2008 04:35 PM
andyd
Jul 9, 2008 01:55 AM
