spark plug can only be screwed in once?
Old Jul 14, 2010 | 11:39 PM
mxl180's Avatar
I turn one plug by hand and then turn back socket wrench but forget if i did 1/2 or 3/4 ( i wanted to do 3/4)... so I unscrewed it and tried again. But I think now the washer is flatten so when I screw by hand, it's tight already?
Old Jul 15, 2010 | 02:30 AM
koolkevin1107's Avatar
No just tighten it. The washer will flatten, but not enough for you to not reuse it. Just do it hand tight then 1/4 turn with the socket.
Old Jul 15, 2010 | 01:24 PM
nikita's Avatar
With washer instead of conical type sparkplugs, its better to use a torque wrench if you can, but go on the low side of spec. Aluminum heads are not forgiving to ham-fisted mechanics.
Old Aug 1, 2010 | 11:21 AM
Oxygen's Avatar
Also, it would be a good idea to use a little anti-seize lubricant on the threads so that it will make it easier to get them out later on.
Old Aug 2, 2010 | 07:47 PM
Goldcoaster's Avatar
Amen on this, if you leave plugs in there for a long time with no anti-seize on there the threads of the plugs (steel) can gall against the head (aluminum) and since steel is stronger than aluminum guess what gets ripped out? Yeah heads are expensive to replace. A little prevention goes a long way.
Old Aug 2, 2010 | 09:25 PM
Krimson_Cardnal's Avatar
Anti-seize and torque to 13ft/lb.
Triskelion
Sep 23, 2022 02:58 AM
SilverEX15
21
Aug 2, 2020 11:19 PM
doctor J
Jan 22, 2019 11:45 PM
doctor J
Aug 26, 2016 03:33 AM
mxl180
Jul 14, 2012 07:42 PM
