need new rims for my 2007 fit sport
Old Oct 1, 2010 | 12:46 PM
07bunnyfit's Avatar
Hello,
I need new tires and my rims are pretty beat both stockers, so i need to figure out what to buy or get next.
So can anyone shed some light into what I should get can I use rsx rims or civic ect... and if so could you provide the year of the cars for me that match thank you!
Old Oct 1, 2010 | 01:03 PM
Hootie's Avatar
If you are looking at only OEM rims then you will have to look for rims with a 4 x 100 bolt pattern. LS Meshs, GSR Blades, BMW-MINI wheels (Between 14" to 17"", and other wheels with that bolt pattern should work as long as they should work so long as they have the proper offset and backspacing to clear the brake caliper.
Old Oct 2, 2010 | 02:47 AM
07bunnyfit's Avatar
thanks I would like to stick to a oem feel
do the new si rims work with fits?
I saw a si with multi spot stock rims looked nice
Old Oct 2, 2010 | 02:08 PM
Hootie's Avatar
If the SI rims you are talking about are split 5 spokes and are on the current roach body Civic, then no. If I recall correctly, those are 5 x 114 and the only way you can mount those is with 4 x 100 to 5 x 114 wheel adapters. Though, a problem with adapters is they act just like spacers and lower the offset of the wheel.
Pretty much the majority of wheels for BMW-MINIs will work, excluding the 18 inch wheels, you will need hub centric rings though.
wheel guide library of motoring
Some of the OEM Honda/Acura wheels I was referring to.
Civic SIs
GSR Blades
LS Mesh
Old Oct 2, 2010 | 07:08 PM
MCFIT1's Avatar
You can find the HFP 16" wheels for cheap online!
Old Oct 2, 2010 | 07:15 PM
Hootie's Avatar
^ Used maybe, new not so much. Still a hair over $150 a wheel for a new HFP wheel.
Honda Fit Alloy Wheels - Genuine 2007-2008 Honda Fit Alloy Wheels
Honda Fit Accessories - Genuine Factory Honda Accessories
^ Sites that I found the prices for new HFPs.
Old Oct 2, 2010 | 07:32 PM
MCFIT1's Avatar
$150 a wheel is cheap!
EMC2
Oct 31, 2012 10:47 AM
EMC2
Jul 23, 2012 01:34 AM
kdean101
Feb 14, 2009 09:53 AM
realjazz
Dec 1, 2006 01:29 AM
dacalac
May 5, 2006 04:18 PM
