P0420 suggestions
Old Nov 19, 2010 | 04:09 PM
ThatsmyFitty's Avatar
Unhappy P0420 suggestions
I'm new here and don't have much knowledge in the automotive side of life so I'll apologize for my ignorance now. Any Help you can give would be greatly appreciated.
So here's the deal. Lately my '07 Fit w/ 150k miles hasn't been running as it should. The car starts fine. I always let it warm up, always do sched oil changes, go to the same gas stations aside from occassionally straying from the norm . The issue starts when I'm driving anywhere between 40 and 60mph (mostly), it happens here and there at other speeds as well, but in that range most of the time. Anyway, foot on the gas, cruising at say 50mph. take my foot off because of traffic, etc. Then slowly start to press the gas peddle again and the car starts to sputter. if I press down hard on the gas it seems fine(no sputtering) but there is loss of power(can't take off as quick as I use to). Also if I have the stereo on, set to aux, with mp3 plugged in but not playing, when the car sputters I get a crackle over the speakers in rhythm with the sputter(strange I know) electrical problem?? The check engine light just came on a couple weeks ago. Got it tested and it came back with a P0420. Did some research on that, possible CAT, O2 sensor, Exhaust. Was just looking for some educated possibilities on my specific problem. I always seem to get hosed at the garage and would like to go in there with a little knowledge. Thanks in advance for any suggestions you may have.
Old Nov 19, 2010 | 05:23 PM
probably the 02 sensor. take it in.
Old Nov 19, 2010 | 07:10 PM
hogwylde's Avatar
I'd like to know how the sensor causes the crackling in the speakers.
Old Nov 19, 2010 | 07:48 PM
JDMchris.com's Avatar
I run THIS
Might be a coil pack. Sounnds more like it than a O2 sensor.
Old Nov 19, 2010 | 08:15 PM
john380's Avatar
It could be while the O2 sensor is malfunctioning it throwing out electrical interference that is being picked up by the radio? In any case I'd check the connector and wiring to the sensor, if all that looks good I'd replace the sensor. Good luck
BenQuick
Apr 3, 2017 11:01 AM
Kixy
Jan 8, 2011 05:35 PM
Mzzchief
Jul 23, 2010 10:27 PM
s0x
Nov 11, 2008 12:46 PM
_Mike_
Mar 10, 2008 10:19 AM
