Wheel spacers.
Old Apr 3, 2011 | 06:52 PM
grooveface's Avatar
Wheel spacers.
Just put 17 inch dr-23 wheels on my 2009 Fit.Was wondering about wheel spacers. I was thinking about 25mm for the rear. Any thoughts?
Old Apr 3, 2011 | 08:22 PM
Perrenoud Fit's Avatar
whats the offset? 40mm?
Old Apr 3, 2011 | 08:23 PM
hayden's Avatar
25 is a lot.
Old Apr 3, 2011 | 08:40 PM
grooveface's Avatar
40mm offset
Old Apr 4, 2011 | 07:14 AM
Bthasht's Avatar
Its possible. Are you lowered? On what? 25mm will probably out poke the fronts. Is your goal to flush with the fronts?
Mount them and measure the difference from lip to fender. Metric tape measure well make that easier.
Old Apr 4, 2011 | 10:27 AM
Ray731's Avatar
Man I want to pics of this! I just ordered 5mm spacers for my rears to bring them out a little. I may have needed to go bigger but 25mm! I gotta see this! Are you looking to poke a little? I just want mine to look like the fronts... flush...
-Ray
Old Apr 4, 2011 | 10:44 AM
ThEvil0nE's Avatar
a total of +15 offset... are you going to run cambers or let it sit the way it is?
Old Apr 4, 2011 | 12:43 PM
grooveface's Avatar
Just measured and 25mm looks like a little much. Def want them to poke out more than the fronts.
Old May 25, 2011 | 01:00 PM
SenBlue09's Avatar
Anyone know how thick of a wheel spacer you can go with without having to buy longer studs??? (for rear, not sure if it makes a dif)
Old May 25, 2011 | 01:12 PM
DSC's Avatar
DSC
I have 15mm spacers and they will definitely need longer studs.
TW216's Avatar
Like 5mm but I still consider those too much
Old May 25, 2011 | 03:50 PM
ATLfit10's Avatar
^this, Ive got 8mm and I havent experienced any issues yet without longer studs but I did lose about 2-3 turns of the lugs with them. I will most likely be extending them soon
Old May 25, 2011 | 08:06 PM
SSMTEN's Avatar
Project Kics Wheel Spacers: Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST
Im thinking about getting these (if I dont get new wheels soon)
More expensive, but you dont have to worry about getting extended studs
bpyoung83
Apr 20, 2015 06:16 PM
Razzer
Jul 19, 2013 05:26 PM
liverpoolfcfan
Mar 29, 2012 08:01 PM
MIAMIFIT
Apr 6, 2010 01:06 AM
mugenfit79
Feb 15, 2010 05:32 PM
