The Form Fresh Suspension Line Up (updated often)
Old Jul 7, 2011 | 10:01 PM
ShopFormFresh's Avatar
Former Vendor
Check us out on Facebook and Twitter!
Email: aaron@shopformfresh.com
Phone: 1-877-527-2261
Website: (under construction) www.shopformfresh.com
PM for pricing and availability!
Silver's NEOMAX Suspension Systems
  • 24 levels of dampening adjustability can be set to any preference
  • 44mm internal piston
  • Mono-tube shock design
  • Italian IP F.A 5W made very high viscosity index guarantees efficient shock-absorbing action at any ambient temperature
  • Lower bracket height adjustability prevents the needs to adjust the spring perch offering the max shock-absorbing travel
  • SAE9254 cold-bent spring is designed to optimize the balance between performance and comfort
KW Variant 2
KW Variant 2 inox-line – Perfect Street Performance
  • Damping technology with individually adjustable rebound
  • inox-line* stainless steel technology
  • Individually height adjustable
  • Adjustment parameters approved by the German Technical Control Board (TÜV)
  • Fully finished complete solution
  • High-quality components for long durability
  • Comprehensive documentation for easy use
Tein Basic Damper
TEIN type BASIC damper offers a high quality coilover system at an entry level price. Drivers will feel in increase in stability, and grip, while maintaining good ride quality on the street and freeway. A shortened shell case is utilized to allow for better ride and improved performance at lowered ride heights. BASIC damper is a great option for consumers wanting a simple and quality made coilover. Each application is test fitted and road tested to ensure the best possible balance between comfort and performance on the street. Includes ride height adjustment to give your vehicle a minor to major drop.
  • Steel Construction
  • Twin Tube internal construction
  • Larger piston diameter for strut type front and rear (22mm)
  • Ride Height adjustable via spring seat
  • Powder coated damper body with Zinc coated threaded section
  • 1-year Manufacturers Defect Warranty
  • Available for Overhaul
Tein Super Street Damper
TEIN Super Street damper kit was designed for drivers seeking improved handling on the street and at the track. A shortened shell case is utilized to allow the most piston stroke possible, which allows for a better ride at lowered ride heights, and increased grip at the track. Great for daily driving and occasion track use, whether it be at the drag strip, local circuit, or Auto-X course. Includes both ride height and damping force adjustment to allow the driver to dial in the suspension for various surface conditions.
  • 16 way adjustable dampers, compression and rebound combined
B&G RS2 Coilover System
RS2 Coilovers put you in complete control with 18 levels of external dampening control (combination of Rebound and compression). Featuring monotube gas charge dampers for quick response and steering control, and a low bleed system to maintain ride quality during normal driving conditions. RS2 incorporates separate adjustments for damper length and spring perch height to allow extreme lowering with full shock travel. For street driving to occasional track use, RS2 Coilovers allow you to dial in the optimal ride height and dampening force for any driving environment.
  • Adjusts height from 1-3.5 inches (Lowering may vary depending on application)
  • 18 way adjustable dampening (combination of rebound and compression)
  • Monotube gas charge dampers
  • High strength anodized aluminum alloy and powder coated steel components
  • Full length height adjustment with separate settings for damper force and spring pre-tension
  • Limited Lifetime Warranty
Cusco Compact, Sport, and Competition Coilover Systems
Ground Control Sleeve Coilover Kit
Kontrol Pro Damper System
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
  • 36 levels of adjustable damping
  • Made from high quality 6061 aluminum with T6 for increased hardness
  • Compression/Rebound adjustable
  • Adjustable spring perch for height adjustment
  • Adjustable body allowing maximum suspension travel
  • Pillowball top mount with adjustable camber (not available for some models)
  • Monotube high pressure design reduces oil leakage
  • Electroplated body for protection from corrosion and rust
  • One year limited warranty
Ksport Rally Spec AR Damper System
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
  • Special designed springs for rally conditions
  • Extended piston stroke
  • Reinforced internals to withstand extreme track conditions
  • 36-way adjustable damping
  • Made from high quality 6061 Aluminum with T6 for increased hardness
  • Pillow ball top mount w/ adjustable camber (not available for some models)
Ksport Airtech Basic Suspension System
Gone are the days of piecing an air suspension system together from several manufacturers and hacking your vehicle up to install your Frankenstein air suspension. Ksport has taken the air suspension industry by storm with the Ksport Airtech Air Suspension System line of products.
All Ksport Airtech Systems feature-
  • High quality air bags, proven to handle the stress and abuse of daily driving as well as drift circuit use.
  • Near infinite adjustability thanks to the adjustable lower mount, 36 levels of damping adjustment, and the unmatched height adjustability (0-200mm) of air suspension.
  • Easy bolt-on installation. No modifications to OEM shock absorbers, or OEM top mounts. Vehicle may need to be modified for air line routing.
  • All Ksport Airtech Systems use VIAIR compressors, and can be raised from the lowest setting to max height in as little as 2 seconds.*
  • All Hoses, wiring, and installation manuals are included.
The Airtech Basic Kit is a complete bolt-on air suspension system, including the following:
  • 5 Gallon air tank
  • (2) 1/4" Ports
  • (2) 3/8" ports
  • 120-150 PSI Pressure Switch
  • (2) Manual Paddle Valves w/ mounting hardware
  • (200 PSI Dual Needle Gauge w/ mounting hardware
  • (4 High Performance Ksport shock absorbers, featuring 36 levels of damping and adjustable lower mount.
  • (4 High Pressure Air Bags designed and engineered to match your vehicle.
  • (Installation manual, all hoses and wiring.
Ksport Airtech Deluxe Air Suspension System
The Airtech Deluxe Kit is a complete bolt-on air suspension system, including the following:
  • Award-Winning Ksport Ride Height Adjustment Remote
  • Electronic Valves (Replaces Manual Paddle Valves)
  • 5 Gallon air tank
  • (2) 1/4" Ports
  • (2) 3/8" ports
Tanabe SUSTEC PRO S-0C
SUSTEC PRO S-0C is for those who desire both high performance and maximum comfort from a suspension system. S-0C is ideal for performance and street applications.
Dispelling a popular belief that a firm or harsh ride is a sign of a performance suspension, the short stroke, shortened case dampener of the S-0C is extremely unique in that its internal construction allows it to deliver superior handling without sacrificing strength or ride comfort.
Unique double-cylinder design allows for full suspension stroke within the shortened shock body while Low-pressure gasses ensure smooth rebound characteristics for additional ride comfort.
Eibach Pro-Kit
he Eibach PRO-KIT is the perfect answer for most frequently-driven street cars. It's our legendary sport spring system that dramatically improves both a vehicle's performance and appearance.
PRO-KIT precisely lowers your car's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach PRO-KIT is the finishing touch to a winning recipe for performance. PRO-KIT also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Every Eibach PRO-KIT is designed and tested by our suspension engineers and performance driving professionals to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, PRO-KIT Performance Springs provide the ultimate balance to take your passion for driving to a whole new level.
Eibach Sportline
Eibach SPORTLINE is the extreme-performance spring set created for the extreme enthusiast - the one who craves a race-car attitude for maximum street performance - with the lowest possible drop, but with the exceptional ride quality you expect from Eibach.
Engineered with the same care as our PRO-KIT springs, Eibach SPORTLINE springs achieve legendary handling by aggressively lowering your car's center of gravity, using our precision - engineered progressive spring rates.
By radically lowering your car's center of gravity, our SPORTLINE springs dramatically reduce squat during acceleration, body roll in corners and nose-dive under braking. By using our proprietary, progressive spring design, our SPORTLINE springs provide the ultimate balance between high performance, extreme lowering and comfortable ride quality. When combined with today's wild 18", 19" or 20" wheels and tires, the result is a car that handles just as white-hot as it looks.
Tein H-Tech Springs
TEIN High.Tech springs utilize the latest spring and material technology to optimize comfort, performance, and quality. Designed and tested in North America to be used in conjunction with OEM or similar shocks for excellent ride comfort and slightly increased handling. The line is produced with Vanadium (SAE9254V), which is durable, lightweight, and has properties to retain more spring stroke. High.Tech springs are designed for those seeking a slightly lowered stance while maintaining high ride quality at a reasonable price. Most vehicles will attain a 1.2 inch drop for a more attractive appearance, added performance, and excellent comfort. Includes a one year limited warranty.
Tein S-Tech Springs
TEIN S.Tech Springs are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
H&R Sport Springs
Sport Spring kits are H&R’s number one selling product. Enhance the look of your vehicle with a reduced fender well gap. H&R Sport Springs lower the vehicle center of gravity and reduce body roll for better handling. The progressive spring rate design provides superb ride quality and comfort. A lower wind resistance signature will make the vehicle more streamlined and improve gas mileage. If you are only looking to improve one part of your vehicle’s suspension, you cannot go wrong with installing Sport Springs. Fun to drive, H&R Sport Springs are the number one upgrade for your vehicle.
Old Jul 11, 2011 | 03:32 PM
Former Vendor
list updated!
Old Jul 19, 2011 | 01:09 PM
Former Vendor
list updated!
gguest
Jun 24, 2019 05:19 PM
ShopFormFresh
Jul 28, 2011 07:08 PM
Bisaya
Apr 5, 2009 03:11 AM
Steeldog
Oct 8, 2008 05:03 PM
tommyinsane
May 17, 2008 02:28 AM
