2008 SSM, finaly posted pics.
Old Jul 24, 2011 | 02:21 AM
UN_FIT's Avatar
Thought I would share some pictures for the rest of you to enjoy.. It isn't much.. But I think i will stop pouring money into the FIT.
Wheels - Enkei 92'2 15x8 +25 (with rear fender rollded, still rubs)
Federal 195/45/15 tires
COMMENTS GOOD OR BAD WELCOME!!
Old Jul 24, 2011 | 02:30 AM
No stickers, color matched hood, no roof rack, and better pics with the wipers down
And it'd look great imo
Old Jul 24, 2011 | 02:56 AM
solbrothers's Avatar
i liek those 92s. needs a touch of camber in front. too much mexipoke for me
Old Jul 24, 2011 | 04:19 AM
vinnymac's Avatar
Lovely, are you springs? Luv those wheels and hood too!
I noticed yur tow hook, babie protrudes out there pretty far huh?
I have one , but I cut the first 2'' of the thread off right at the notch, cut a similar dia hole thru the cover and screw'd it in thru there, now its fairly close to the bumper. After bang'n up my leg a few times on it while detail'n my ryde, I figured, 'nuff already..
carbonfiberfoggies05-15-11012-1.jpg?t=1311494562
dayshawrknonmycar7-22-11.jpg?t=1311496775
Old Jul 24, 2011 | 11:07 AM
UN_FIT's Avatar
The only stickers are the ones on the rack! I need the one on my windshield (Military) and the one on top is a suction cup! And I use the rack for my surfboard quite often not for "cool points" like other people. It's a CF hood so probably not going to paint. AND YES, better pictures with the wipers down!
Thanks for your opinion!
Old Jul 24, 2011 | 11:09 AM
UN_FIT's Avatar
Thanks, been working on the camber for the front. Any suggestions for brands?
Old Jul 24, 2011 | 11:19 AM
UN_FIT's Avatar
Thanks! I'm actually on Skunk 2 coils. I can go probably another inch in the front, but then my lip will be on the ground. And the rears are maxxed out with spring perch. If you notice on the front bumper behind the lip there's a black rubber piece that extends passed the front lip, well mine is all F'd up. For daily driving it's low enough for me. Plus I have a dip in front of my garage for the water drainage. Let's just say i cant go staight in and with my wife's car inside, the degree of angle i can get is not enough and still scrape leaving the garage!
For the Tow Hook, i kinda like having it extended, incase some jerk decides to underestimate at parking, his bumper will get F'd up from the hook before it even touches my car!
Old Jul 24, 2011 | 02:53 PM
infamousAXEL's Avatar
looks good man. Any rubbing issues up front or did you get them rolled/pulled as well?
I'm looking to run a set of 15x8 +25 as well probably on 195/50s but just concerned about rubbing
Old Jul 24, 2011 | 06:30 PM
UN_FIT's Avatar
In the front, it's only when I hit big bumps it will slightly rub but nothing crazy. I got used to it already. But with mOre camber, it should be perfect. The rears need the most work!!
Old Jul 24, 2011 | 09:43 PM
vinnymac's Avatar
For the Tow Hook, i kinda like having it extended, incase some jerk decides to underestimate at parking, his bumper will get F'd up from the hook before it even touches my car! [/quote]
Which reminds me, I have a tow hook in the rear also and it came in handy for the exact reason that you stated. The operator's inattentiveness caused his lip and turn indicator to get ruined (at a stop light) by my rear tow hook with no damages to mine ryde. Bottom line...you've made a valid point
But, I've banged my legs on that one too while tooling around in the cargo area couple times...
Weezy2525
Aug 28, 2012 09:00 PM
chunkylover8200
Jul 3, 2010 10:42 PM
score04w
Jun 3, 2010 06:19 PM
davela72
Mar 13, 2008 10:01 PM
mmmkelley
Jun 8, 2007 02:22 AM
