Please help me out about the speakers
Old Aug 3, 2011 | 10:25 PM
pp0225's Avatar
Hi guys,
I searched how to replace a speakers in the front, and they said there is three screws that I have to look out in center of the door, but I dont know how to remove the centre of the console. Could you guys tell me how to get in to? Please.....
Old Aug 4, 2011 | 12:44 AM
kodok3ribu's Avatar
you need to take off the hand grab first.. there's a sort of clip that you can push back on the bottom side of the hand grab and pull it out. beyond that handgrab are the 3 screws. also be careful with the door opener, after you unscrew it, you need to slide it forward first, than it will come loose and you can take it off.
it'd be better if someone has the diagram..
Old Aug 4, 2011 | 04:39 PM
pp0225's Avatar
The arm rest is hard to remove... no luck today....
Old Aug 4, 2011 | 10:25 PM
kodok3ribu's Avatar
ya, it's hard, especially if never opened before... my method of opening, i use 3 flathead screwdriver. there are 3 clips below the arm rest. i pushed the 1st clip and pull on the arm rest. then i wedge another screwdiver into the gap between the arm rest and the door panel.. then continue on with the 2nd clip. it's hard, and can take some time. and you might want to wrap the screwdriver with cloth, otherwise you'll easily mess up your door panel..
oblio125
Aug 25, 2012 01:05 AM
Ciggy
May 14, 2010 03:25 PM
sy11580
Dec 20, 2008 08:20 PM
pwnstar
Jun 16, 2008 03:50 AM
micchung
Mar 29, 2008 07:12 PM
