Fit just hit 30,000
Old Sep 29, 2011 | 03:48 AM
johnsaldivar's Avatar
Fit just hit 30,000
My 2009 fit Sport just hit its 30,000 mark and the so far no wrenches and oil is showing 20% should I wait till it says to do something or do it any ways. thanks for any info.
Old Sep 29, 2011 | 05:08 AM
Goobers's Avatar
30k miles?!? And no wrench/service indicator in all that time? (even if it's 30k kilometers, that's still a lot).
Well, I suppose it's possible if its all light highway driving.
But, if you've had your Fit for more than a year, the limit is 1 year. If you don't get the light after 12 months, you're supposed to get it done anyway.
Old Sep 29, 2011 | 08:05 AM
FRAMEshift's Avatar
30K miles is not possible unless the car is only driven downhill.
30K kilometers is 18.8K Miles and even that sounds like a malfunction of the oil monitoring system.
Drive (very carefully) to a Honda dealer and have the oil changed and the system checked.
Old Sep 29, 2011 | 09:00 AM
mhadden's Avatar
Yes, somewhere along the line the MM system was reset...
Old Sep 29, 2011 | 09:14 AM
SilverbulletCSVT's Avatar
I don't think he is saying this is his first oil change. Just that he has never seen a service wrench. If oil changes previously done before MM reaching 15% life, then true he would have never seen a service wrench. Only the oil change shop would have seen the wrench while resetting his MM.
_
Old Sep 29, 2011 | 10:35 AM
RevToTheRedline's Avatar
I'm about to hit 20k.. I'm happy so far cause my old VW GTI already had major problems off and on in that few miles.
Old Sep 29, 2011 | 12:27 PM
Subie's Avatar
My MM wrench comes on at 15%. Last oil change I logged approx. 6k+ miles till my MM wrench light came on again @ 15%.
Old Sep 29, 2011 | 02:46 PM
the wrench light i read goes by engine rpm rather than milage so just follow wat the maintenance reminder aka wrench says.
my 09 has about 26K miles so not too far behind. i did an oil change last weekend.
Old Sep 29, 2011 | 02:53 PM
Speedee 09 Fit's Avatar
I just hit 60k yesterday , now on my third set of tires. I've followed the MM every time, and it seems to be rolling around at about 11k per oil change. I drive mostly highway so I know that's why it is going so long between changes.
Old Sep 29, 2011 | 09:15 PM
JJIN's Avatar
my 09' is about to hit 70k in about 1,200 miles.
ive noticed my fit has been running a bit sluggish lately. i gave it an oil change every 8k miles since new, with hamp oil filters and mobile 1 5w-20. i also wash and oil my prm air filter every oil change. dont really know why its being lazy...
also, ive never waited till the wrench came on. i dont even know what the wrench looks like.
Old Sep 30, 2011 | 07:57 AM
Hondafrk's Avatar
Looks like...a wrench. Comes on every single time you turn the ignition on...no way you haven't seen it.
Old Sep 30, 2011 | 09:46 AM
fawbusha's Avatar
Tried injector cleaner? I use Lucas every oil change
Old Sep 30, 2011 | 10:37 AM
when you cleaned your air filter did you oil it too much? check the MAF.
Old Sep 30, 2011 | 11:03 AM
JJIN's Avatar
I only oil the filter lightly as not to soak the element so I know its not the MAF.
I guess I never really looked carefully at the gauges when starting up but I do look when all lights go out and to see if cel or tpms are on. You're right the wrench is under the 0 on the speedo.
I've tried octane booster/injector cleaner. I think I should try another bottle.
p1co
Oct 25, 2017 02:21 PM
fufit905
Aug 27, 2010 07:35 PM
DeeGee
Feb 2, 2010 12:41 AM
mole177
Feb 16, 2009 01:19 PM
geepondy
Sep 4, 2008 04:24 PM
