2012 fit sport k&n intake???????
Old Nov 2, 2011 | 03:43 PM
Ekim2323's Avatar
Had anyone with the new 2012 fit put a k& n typoon on there fit? I really want one but no matter where I check I can't get a confirmation that it will fit the new model fit has anyone done this yet? Thanks
Old Nov 2, 2011 | 05:18 PM
kirinzon's Avatar
Save your $$$$ for something else and use the drop in k&n filter. Just as good IMO.
Old Nov 2, 2011 | 05:40 PM
not even drop-ins. just keep it stock.
Old Nov 3, 2011 | 01:10 AM
Ekim2323's Avatar
thanks for the suggestions I will consider the drop in filter when its time to change it out ,hopefully by then the stock filter doesn't cost more then the k&n :]
Old Nov 3, 2011 | 02:11 AM
Krisisfit's Avatar
i got the new honda fit 2012 a month ago , i changed my stock filter to a K&N filter . i was planning to put cold air intake but i dont wanna waste my warranty so ill stay with stock . and im doing the exterior first before all the things inside the hood .
Old Nov 3, 2011 | 06:13 PM
SSMTEN's Avatar
To actually answer the op's question..... Im pretty sure it WILL work with the 2012's. They didnt change anything with the engine or the ECU, so any GE8 intake should work. The Typhoon is good because it works with M/T and A/T.
Old Nov 3, 2011 | 06:16 PM
JDMxGE8's Avatar
I totally agree. It should work on the 2012 without any problems. If you really want to make sure, give K&N a call.
Old Feb 4, 2012 | 07:48 AM
LeAJazz's Avatar
Do you guys know anything about the Takeda cold air intakes ? Was wondering if they would fit the 2012 fit sport A/T with paddle shifts.
Old Nov 30, 2012 | 10:21 PM
dasautoatheart's Avatar
Is a drop in even worth it?
Old Dec 1, 2012 | 09:01 AM
specboy's Avatar
No intake is worth it on the fit unless you are going for a different Sound or you just don't want to use disposable filters. The ECU Adjusts to the intake over a fairly short period of time and any performance gains you get at first are negated. The ECU is tuned for Economy and accordingly, it adjusts itself automatically to meet those needs. Performance upgrades on the fit are limited to suspension, grip, and Weight reduction. HP without a custom forced induction system isn't really an option.
~SB
Old Dec 3, 2012 | 10:04 AM
Bama3Dr's Avatar
Like these guys said, yes it will work, but don't expect any real gains in power. At best you'll get more engine growl under hard acceleration and maybe a slight bump in mpg (if you can keep your foot out of it!).
I'm planning on getting a PRM intake for my 2012 Sport Auto just for the sound. On the videos I've seen the Fit engine sounds awesome with an intake!
-Dustin
Old Dec 3, 2012 | 11:11 PM
Colincarguy's Avatar
As someone who actually has a Typhoon intake on their fit, not just speculators, It will fit your "fit". You get much more intake noise under the hood, enough so that in parking garages and underpasses, its actually pretty loud (but sounds great). Not really much of an increase in MPGs, however there is a noticable increase in torque around 4,000 RPM, along with a nice noticeable increase in sound (VTEC engaging?)
Worth the money for sure.
Old Dec 4, 2012 | 05:08 PM
AdvansCPAP's Avatar
1+. I have a 2012 5spd Sport with the typhoon. It fits fine and worth it for just the sound since that was the only reason it was purchased for.
Old Dec 5, 2012 | 12:33 AM
pouncer11's Avatar
I would spend that money on a nice set of wheels and tires to wrap around them :P
Old Dec 6, 2012 | 01:03 PM
p nut's Avatar
Just be careful with those K&N (and other aftermarket) filters. The silicone levels in my oil spiked way up when I used a K&N. This usually means dirt getting through the filter. Changed back to factory paper and all is normal.
Old Dec 11, 2012 | 02:11 PM
nikita's Avatar
Bingo! The other downside of oiled cloth filters is that the dirt that passes, along with a slight oil mist can coat the MAF sensor wire, throwing a CEL code.
Old Dec 11, 2012 | 04:46 PM
Sloppy_Snood's Avatar
CAI = "Auditory HP"
Old Dec 11, 2012 | 09:28 PM
Speedlimitz's Avatar
Buy my injen intake!
Old Dec 19, 2012 | 02:38 PM
AdvansCPAP's Avatar
After reading up more on oiled cone filters, I picked up and AEM dryflow (21-2011DK). Fits perfectly and looks much nicer than the tiny K&N the Typhoon comes with. No difference in sound, but more peace of mind knowing there will not be any oil or as much dirt seeping through.
Old Dec 19, 2012 | 02:49 PM
Mini_Odyssey's Avatar
2009-2013 intake should all fit the same, with the exception of Automatic models on some cold air intakes dont seem to fit.
