My Car Won't Start!!
Old Jul 10, 2006 | 08:58 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
This morning when I went to get into my car and start it NOTHING HAPPENED! The gauges didn't come one, it beeped once and then nothing happend.. the wheel didn't even lock and the gauges didn't light! Nothing.. I could turn the key w/out it locking too.. I had to take my mom's 626 to work and when I get home today I will try and fix it.. I think its the battery but nothing I have done would have messed with the battery onlything like that would of been a grounding kit, no wires are near the postive termnial though.. any ideas or should I just call honda?
Old Jul 10, 2006 | 09:04 AM
fitaholic's Avatar
When you get home try jumping the battery or cleaning the terminals and see if that works. Did you leave your lights on overnight or something? I don't see why your new cars battery would already be dead.
Let us know what you find out.
Forgot to ask...is your CEL on??
More than likely it is something really simple.
Good luck!
oOo LinDa's Avatar
Senior Member
that really sucks!!
I would say call Honda first since your at work and just inquire bout it then go home and check your battery to be sure.
Old Jul 10, 2006 | 09:05 AM
NCFit's Avatar
Post
Just something to take into consideration, when a tailight or marker bulb goes out on my Tacoma, it will not start. I did not realize this until after I had it towed. So maybe check all of the bulbs on the car.... other than that I would just call Honda and let them know. GOOD LUCK!
Old Jul 10, 2006 | 09:09 AM
sLiVeRwOrM's Avatar
Well I had not recently got gas, and I did not leave my lights on...
Old Jul 10, 2006 | 09:12 AM
fitaholic's Avatar
Does you CEL come on?? I'm doubting it has. How many miles now on your Fit?
Old Jul 10, 2006 | 09:13 AM
sLiVeRwOrM's Avatar
No gauges come on. Nothing happens. The wheel doesn't even lock..
Old Jul 10, 2006 | 09:16 AM
fitaholic's Avatar
Has to be the battery. If it doesn't jump start then you know it is dead.
Old Jul 10, 2006 | 09:20 AM
ccFit's Avatar
may be the (-) terminal is loose after installing the grounding kit
Old Jul 10, 2006 | 09:22 AM
fitaholic's Avatar
^^^ good point. Faulty connection. Tighten the terminals and check for corrosion.
Old Jul 10, 2006 | 09:24 AM
sLiVeRwOrM's Avatar
Thanks for all the info I will get home about 2 and start.. first thing is checking the tightness on the termnials then try to jump it..
Old Jul 10, 2006 | 11:25 AM
coldstorage5's Avatar
Dude , try to relax, im sure its nothing big. check all doors, (rear) proberly a light was left on. Then give it a jump. You'll be fine
Old Jul 10, 2006 | 11:26 AM
buttahball's Avatar
hmmm...interesting...(about the tail light on the tacoma)
Old Jul 10, 2006 | 11:29 AM
einhan's Avatar
What Did You Do To Your Car?!?!?!?
edit: ghey, i cant type all caps?!?!
Old Jul 10, 2006 | 11:32 AM
sLiVeRwOrM's Avatar
lol, iam sure no lights were on.. but i will double check.. mabye iam wrong.. a simple jump should work i hope ::fingers crossed::
Old Jul 10, 2006 | 11:36 AM
aziatiklover's Avatar
Master FitFreaker
I would say battery just get the battery warranty
Old Jul 10, 2006 | 11:47 AM
sLiVeRwOrM's Avatar
we will see.. lol ill read the little meter thing on the battery ( o ) means its good! lol
Old Jul 10, 2006 | 12:23 PM
nexus4400's Avatar
I accidentally left my door ajar the other day. I come to find out that the interior MAP light turns itself off after a set time. Make sure your negative cable is properly tightened. Battery could also be a dud.
Old Jul 10, 2006 | 12:26 PM
sLiVeRwOrM's Avatar
it could possibly be me acting retarted and leaving the lights on because the day before I was flashing people my lights to warn of a cop ahead.. so i could of just left em on..
Old Jul 10, 2006 | 12:50 PM
oOo LinDa's Avatar
Senior Member
^^ haha, maybe you left them on on accident
