Gd3 buddyclub noise help!!!
Old Dec 30, 2011 | 10:49 PM
konespeed's Avatar
So I installed my coils however my front coils are making a popping noise when I turn the u- turn point either right or left. I don't know wat to do. I've tried to tighten the spring but still noise should I tighten it more? I'll upload pics asap
Old Dec 30, 2011 | 10:55 PM
I feel like its something to do with the sway bar end links, but that's just guessing from memory.
Old Jan 2, 2012 | 05:19 PM
KSPORT's Avatar
This is a common issue when your preload isnt set properly.
What are you using to tighten the spring perch and locking collar? If you are using the spanner wrenches it will come loose take a flat head screw driver put electrical tape on the end, grab a hammer and place the flat head in the grooves and tap til tight.
Old Jan 23, 2012 | 06:47 PM
AJ PwR Jr.'s Avatar
Former Vendor
Front or rear suspension making the noise ?
Old Jan 24, 2012 | 12:31 PM
konespeed's Avatar
its the front suspension thats making the noise. lubing up the spring stops the noise for a bit.. but it's coming back again after the wd-40 evaporated.
Old Jan 19, 2013 | 12:45 PM
TurboDatFit's Avatar
Hey AJ
Do you have an answer to this issue? I have this same problem whenever I turn... I'm freaking out because I'm not sure what it is. I'll recheck my preload again. But I'm pretty sure it's set right. I'm on a ge8.
Andy
jy1129
Jul 31, 2020 02:23 AM
Eamper
Mar 11, 2011 07:27 AM
kingofpicklez
Nov 22, 2009 03:31 PM
NBPturtle
May 29, 2008 09:52 AM
