K Sport Coilovers Rear Springs Super Soft!!
Old Jan 8, 2012 | 10:50 PM
mintyPham's Avatar
Hello fitfreak! i recently installed K sport coilovers on my gd3, and whenever someone sits (about 150lbs) in the back seats, the rear (2 finger gap) just dumps all the way to the wheel causing me to rub like crazy. I already adjusted the knob on top all the way to "H". is anyone else with K Sport Coilovers having this problem? Or does anyone know what i can do to make them stiffer?
also, ive rolled my rear fenders, but i havent cut the insides of my rear bumper yet, but that shouldn't have to do with the springs being too soft.
Old Jan 9, 2012 | 05:09 PM
KSPORT's Avatar
Hey OP, we can get you stiffer spring rate. They are special order since the Fit is a high low set up in the rear but we can help you out 100%
-Jade
Old Jan 10, 2012 | 03:03 AM
mintyPham's Avatar
pm sent! thanks Jade ))
Old Jan 10, 2012 | 07:24 AM
SickFit's Avatar
You may have a blown shock. Yes, even if they're new, they could arrive defective.
Old Jan 10, 2012 | 09:54 AM
nxtfit_08's Avatar
or you could just do the rear airshock mod
Old Jan 10, 2012 | 01:41 PM
mintyPham's Avatar
How can i double check.? I sure hope not :<
haha, pm replied! ^_^Y
Old Jan 10, 2012 | 04:42 PM
Goobers's Avatar
take the rear shocks out and see how easy it is to compress. or... if you see fluid oozing from it.
Old Jan 10, 2012 | 05:28 PM
Texas Coyote's Avatar
It sounds like you have the struts set too low and (or) wheels without enough offset, rims too wide, tires too wide or a little bit of all of those things....
Old Jan 10, 2012 | 07:12 PM
mintyPham's Avatar
struts..? wheres that located? and how can i adjust it?
pardon my lack of knowledge, but i gotta start somewhere right? haha
Old Jan 11, 2012 | 12:11 AM
nxtfit_08's Avatar
Old Jan 11, 2012 | 12:56 AM
From the OP it doesn't seem like the car is too low. Most likely he just got stuck with a bad product.
Not exactly unexpected considering the manufacturer. :door:
Old Jan 11, 2012 | 01:08 AM
solbrothers's Avatar
lulz this entirely
Old Jan 11, 2012 | 01:29 AM
I'm going to leave this alone until I get my Buddy Club N+ coilovers dialed in... Damned Japanese instructions aren't very helpful and I am being very cautious It looks like I should be able to set them high enough that I won't look like a retard when avoiding scraping the front lip or bashing the underside on speed bumps.
magellows
Jan 30, 2019 04:36 PM
killswitch9
Nov 3, 2014 06:32 PM
duzntFIT
Dec 11, 2013 12:06 AM
da9r00d
Nov 21, 2008 11:49 AM
ev0le
Jul 13, 2008 08:00 AM
