BBS rs wheels.
Old Feb 1, 2012 | 06:42 PM
Metafit's Avatar
BBS rs wheels.
I plan on getting those rims and I was wondering what's best fit for it so I won't have to push the fenders nor do much to Destory my car. What size? I like the rim to stick out longer then my fender and also how slammed should I go? I just bought a fit 07 sport and I don't know much yet. Just slammed and rims is what I'm looking for first.
Old Feb 1, 2012 | 06:47 PM
MNfit's Avatar
Well for starters welcome to FF, I see your from St. Paul MN, thats awesome! We dont have many MN guys on here.
For your question im not really sure what your asking, I had some 15x7 +32 offset on my Fit and it was pretty much flush with the front fender. The only mod i did was to remove a clip on the fender liner and push the lining up over the fender lip.
Old Feb 1, 2012 | 06:50 PM
Metafit's Avatar
You think 15 would be too small if I slam it? Cause you want it big for it to stick out once you slam. Maybe 16 or 17s?
Old Feb 1, 2012 | 07:00 PM
MNfit's Avatar
what do you mean stick out? you tring to go for the hellaflush look? The wheel will look stupiod sticking past the fenders.
My Car on 15s lowered on skunk 2 coilovers
Old Feb 1, 2012 | 07:07 PM
Metafit's Avatar
Old Feb 1, 2012 | 07:12 PM
Metafit's Avatar
Something like that. It sticks out quiet well.
Old Feb 1, 2012 | 07:14 PM
DreaMv's Avatar
those look like 16x8 +15 ish?
who's fit is that?
Old Feb 1, 2012 | 07:18 PM
MNfit's Avatar
im pretty sure that is towelie's old Fit.
what I found for is wheel spec
15x8+?? (f)
15x8.5+?? (R)
Old Feb 1, 2012 | 07:39 PM
Metafit's Avatar
Hmm his is already 15 high. I wonder how 16 would look like 16x7 front 16x8
Old Feb 1, 2012 | 08:00 PM
MNfit's Avatar
I dont see why not
Old Feb 1, 2012 | 08:06 PM
Metafit's Avatar
So what brings out the flush from the numbers? *ex. #x# + #(set)
Old Feb 1, 2012 | 08:14 PM
MNfit's Avatar
what? your going to need a lower offset to bring the wheels flush. that you will have to figure out with some math
Old Feb 1, 2012 | 08:18 PM
Metafit's Avatar
Let's say 16x7 front and 16x8 back what can I figure out? Outta that?
Old Feb 1, 2012 | 09:53 PM
MNfit's Avatar
no idea, im not good with math and figuring out the whole offset BS
Old Feb 1, 2012 | 10:05 PM
vinnymac's Avatar
rep++Good answer, I'm not either...
Old Feb 1, 2012 | 10:56 PM
DreaMv's Avatar
Old Feb 1, 2012 | 11:46 PM
In order to get stupid fitment like that you'll most likely need (just a quick estimate based on eyeballing it):
16x8 +15 up front
16x8.5 +12 in back
Old Feb 1, 2012 | 11:48 PM
DreaMv's Avatar
Also, that last picture was him having -7 camber in the rear.
Old Feb 3, 2012 | 01:51 AM
ivanjm422's Avatar
wait so these are +32 offset and no fender modding was needed besides the inside fender lining? What tire size were you running? :O
Old Feb 3, 2012 | 05:08 AM
MNfit's Avatar
195/50/15 I also had a 5mm spacer out back so the rears where actualy +27. It did rub, actually a lot with the 5mm spacer out back, the tire would hit the inside fender lip over every decent bump. The fronts would also rub over bumps and hard turns. Was it enough for me to care, no.
