Would 15" wheels with +38 offset fit?
Old Apr 25, 2012 | 11:29 PM
EMC2's Avatar
Question Would 15" wheels with +38 offset fit?
I am considering buying a used set of Rota Attack wheels for my 2007 Fit. The wheels have +38 offset. I have the option to buy the wheels installed with 205/50/15 tires or without tires. If I purchase the wheels without tires, then I am considering installing either 195/50/15 or 195/55/15. My question is- would these wheels fit my car with all 3 sizes? I don't intend to lower my car.
Old Apr 25, 2012 | 11:41 PM
Yes it will.
References:
Myself @ 15x7 +37 w/ 195/50
Mike410 @ 15x7 +35 w/ 195/50 (Both of us on Yoko S.Drives)
Old Apr 26, 2012 | 12:57 AM
fitster's Avatar
yes it will i use to run rota attacks 15x7 et38 with 5mm spacer
205/50/15
and lowered
not a problem at all
Old Apr 26, 2012 | 12:59 AM
EMC2's Avatar
These Rota Attacks are 15x6.5. I assume they still require the spacers?
Old Apr 26, 2012 | 01:20 AM
sfar785's Avatar
my Spun Supamesh were 15x7.5 with a +40 offset and they worked fine, just gotta have a 205/60/15 if you aren't lowered...but if you are you can go xxx/50 or xxx/55.
Old Apr 26, 2012 | 03:41 PM
EMC2's Avatar
Question
What would be the difference in performance vs. fuel economy between the 195/50/15 and the 205/50/15? The prices for 195/50/15 tires are considerably lower than the 205/50/15, so this seems to be a logical choice.
Old Apr 26, 2012 | 04:14 PM
He owns a GD. Your GE info has zero bearing on this matter.
Old Apr 26, 2012 | 04:40 PM
Wanderer.'s Avatar
I wouldn't worry about spacers if you're not going to lower the car, you don't NEED them unless you're running like +55 wheels or something like that.
Just get 195/50, they're cheaper, it doesn't seem like you will notice or need the extra 10mm of width. 195/50 will look better on 15x6.5 and will more than likely be a tiny bit lighter.
Old Apr 26, 2012 | 05:31 PM
205 is way too much tyre for a 6.5j IMO.
Old Apr 26, 2012 | 05:46 PM
Texas Coyote's Avatar
Most 205-50s are too heavy for use on a 1500cc station wagon, they fit very well on 6 1/2" wide wheel rims though.
Old Apr 30, 2012 | 02:39 AM
FITFITFITFITFIT's Avatar
Not to hijack the tread. I'm purchasing a set of used rim
15x6.5 +38 offset
195/50/15 yokohama s drive
2007 base fit not lowered
Will this fit and drive perfectly?
Old Apr 30, 2012 | 04:28 AM
That sounds like a pretty cool combination to me...
Old May 3, 2012 | 01:57 PM
cokeismetal's Avatar
i have a 2011 fit. its lowered but i wanna get wheels. i was thinking about the rota grid v 15x8 0mm, or rota j-mag 15x7 +40mm. which is a better choice?
Old May 3, 2012 | 02:01 PM
sfar785's Avatar
i personally like the J-Mag in +40 but IMO i'd go 16x7 and a 195/50/16 for a tire
Old May 3, 2012 | 02:25 PM
but i kinda like the stretched look. i wanted my car to be low and wide
Old May 3, 2012 | 02:26 PM
im just so dumb when it comes to figuring this stuff out
Old May 3, 2012 | 02:37 PM
sfar785's Avatar
well if you go under +25 offset you're gonna have to roll your fenders. Look into the XXR 002 (0 offset) if you wanna stretch, get the 16x9 with a 195/40/16
Old May 3, 2012 | 03:08 PM
Gah that would suck so much.
And have you ever considered how awful that would fit? Sfar, do you realize how small the wheel wells are on Honda Fits?
Old May 3, 2012 | 03:22 PM
sfar785's Avatar
yes, i do know this which is why you "roll" the fenders. He wants an offset so i gave him an offset. I also know someone with 002's, no stretched tires but it doesn't look bad at all.
so.. what would i have to do to make the wheels flush?
