Fortune Auto coilovers Generation IV are coming to JB Autosports!
Old Jun 11, 2012 | 11:43 AM
JBAutosports's Avatar
Former Vendor
Fortune Auto Generation IV coilovers have just been announced!!!
So, the big question will be what has changed,right? Well here it is, straight from the lions mouth...
Revised Jetting - When the Fortune Auto engineers designed the Generation 4 Series, they made it a priority to revise the jetting for more accurate damper control. The engineers also increased the adjustment range. Every click in the adjustment range now has a very profound effect on damping force and each click is very audible and distinct. We responded to our clients' comments regarding the lack of audible distinction in the clicking mechanism. Our desire is to constantly refine our products using the valuable feedback from our clients, so we have addressed this issue with our Generation 4 shocks.
Stronger Piston Shafts - The data we have compiled through our racing program has been thoroughly implemented in our new Generation 4 Series. The delicate science behind the strength of piston shafts can be difficult to perfect. If the shaft is too hard, it will be brittle and break easily, but if the shaft is too soft it will bend too easily. Through extensive R&D we were able to achieve an optimal balance between shaft hardness and malleability in the Generation 4 Series to ensure peak safety and performance.
Lower Friction Shaft Seals - The new Generation 4 shaft seals have 40% less drag than our previous models. This provides for less hysteresis and for superior control of driver inputs. Our new seals are made of a specially formulated Buna rubber compound that provides a great balance between reliability and performance! Since the shaft seal is the most important seal on the shock, a stronger seal will greatly improve quality and performance.
Improved Shaft Cap Design - Our new shaft caps utilize a twin O-ring design. Furthermore we have upgraded our rubber O-rings to Viton O-rings. The new Viton O-rings are made of a synthetic rubber compound which provides a superior tensile strength and a wider range of operating temperatures. This new design provides a superior seal preventing potential leaks from developing.
Structural Improvements - Utilizing our engineers' in-house design software we were able to revamp our whole line of suspension in the Generation 4 Series. We reinforced brackets and mounting points for more rigidity and strength. We also replaced the rubber bushings in the eye-bolt style lower brackets and upgraded them to urethane bushings.
Brake Line Brackets - Now all models will have OEM brake line tabs welded to the lower mounts. This provides the end user with a clean and safe install solution.
Digressive & Ultra Digressive Pistons - To ensure superior ride quality and driver control, the digressive piston technology on our 500 and 510 series has been carried over to the Generation 4 Series as well. All Generation 4 shock absorbers will continue to utilize our digressive piston technology on our 500 series models and ultra digressive piston technology on our 510 series models. Digressive piston technology allows for massive amounts of low speed rebound force that translates driver inputs into razor sharp control. Furthermore, the rebound force "blows off" to provide the driver with a supple and compliant ride while maintaining superior mechanical grip over rough surfaces.
Dyno-tuned and Tested - Our commitment to providing the best shock absorber in the market has not changed with the Generation 4 Series. EVERY shock absorber is still dyno-tested at our facility. We do not spot check our shocks like some other manufacturers. Once your shock absorber is built it is tested and matched. We refuse to treat our shocks with a “one size fits all” mentality. Our philosophy is simple. We provide our clients with a high quality, affordable, and personalized suspension solution.
Fortune Auto 500 cut-out showing improvements!
Fortune Auto 510 cut-out showing improvements!
All of this and still at a very affordable price! This is definitely a great entry-level coilover! Fortune Auto is continuosly stepping up its game to bring value and the most bang for the buck. This is the sort of product we at JB Autosports appreciate and like to promote. If you want pricing or want to place an order, feel free to contact us directly. This is not a For Sale thread, but mainly for information purposes.
Thanks for reading!
Old Jun 12, 2012 | 02:54 PM
Former Vendor
Bumpity.
Old Jun 12, 2012 | 07:33 PM
zilla8's Avatar
what is the difference between the 500/510 besides price?
Old Jun 12, 2012 | 08:14 PM
krunk13's Avatar
Different piston diameter....500= 53-57mm. 510=58mm piston
Old Jun 12, 2012 | 08:33 PM
Wanderer.'s Avatar
Why are the spring rates offered 6k/3k for a Fit? Seems kind of silly. Do they offer custom springrates with the order or would I have to get different springs from Eibach or Swift, and in that case do you know the included springs I.D?
Old Jun 12, 2012 | 08:40 PM
krunk13's Avatar
Seems like thats what lots of coilovers for the Fit run.
Old Jun 12, 2012 | 10:42 PM
555sexydrive's Avatar
12fr/8rr is lovely.
Old Jun 13, 2012 | 02:40 PM
Wanderer.'s Avatar
12fr/8rr is lovely.
now that's what i'm talking about.
6/3 just seems so forward biased, idk, 6/4 seems more appropriate, most of the C/O I've seen are more like 6/5, I think HKS was 6/6.5 (wheee)
If it's for comfort so the rear isn't so stiff with no weight over it i'd think the 6/3 rate would be for the comfort setup and they'd have different rates for the other setups, but they're all the same......
Old Jun 14, 2012 | 11:27 AM
Former Vendor
Nearing the weekend bump.
Old Jun 15, 2012 | 02:30 PM
Former Vendor
We can do custom spring rates for no charge with Fortune brand springs. You can also do whatever rates you want with SWIFT springs for an additional charge of $325.
Old Jun 16, 2012 | 02:04 PM
Former Vendor
Weekend bump.
Old Jun 18, 2012 | 01:57 PM
Wanderer.'s Avatar
Great! Thanks for the info.
Old Jun 18, 2012 | 06:16 PM
Former Vendor
My pleasure!
Old Jun 19, 2012 | 02:01 PM
Former Vendor
Bumparooski.
Old Jun 20, 2012 | 05:15 PM
Former Vendor
Bump it up.
Old Jun 21, 2012 | 06:16 PM
Former Vendor
Bump for some great coilovers.
Old Jun 22, 2012 | 03:48 PM
Former Vendor
End of the week bump.
Old Jun 23, 2012 | 07:22 PM
Former Vendor
Weekend bump!
Old Jun 25, 2012 | 02:54 PM
purplecreeper's Avatar
There is no phone number on ur website
Old Jun 25, 2012 | 06:59 PM
Former Vendor
It is under the contact us section. You can also check our signature.
