DU MA! SUBFRAME&SWAY BARS?! help plz! I'm a nub
Hello everybody,
So I'm planning to invest in a sway bars. But some of my friends say that sway bars can ruin the chassis and that you have to get a subframe to aviod it. So I was wondering if you really HAVE to get a subframe. I wouldn't mind getting both, but I'm ballin on a budget ! B)
ALSO, I was wondering which brands are good. I was looking into buying cusco sway bars and type one racing underbrace.
Hello everybody,
I have the Progress rsb and trust me It's all you need for the street/track on a otherwise stock motor Fit.
Add Swift springs and sticky tires/light wheels and you are set.You will not have enough power to overwhelm the suspension in most cases.
If you don't run giant diameter swaybars you won't have any chassis problems. I think your friends are talking about swaybars that have center mounting points attached to the body, and yes, if you get one that is too big you do have to reinforce that body mounting point or it can get ripped out.
As far as the Fit and the Progress style bar it does not mount to the body so you should have no issues. As far as I know none of the sway bars available for the Fit are that large that this should be an issue, even in the front.
Nicotine
19
Sep 10, 2014 01:50 PM
mholbrook38
Dec 4, 2010 04:18 PM
xm8
Aug 8, 2010 05:18 AM
thedeadpoet000
17
Sep 18, 2007 09:52 AM
