fuse issue?
Old Dec 24, 2012 | 10:58 AM
goalie35's Avatar
Angry fuse issue?
2010 honda fit manual
Remote entry does not work
With power off door locks not working
Power on car running locks work but radio not working. no dash warnign lights to guide on.
Any help here?
Old Dec 24, 2012 | 04:32 PM
Black3sr's Avatar
Any help here?
Could be a fuse. Check the manual for which one to look at.
Green arrow shows the white fuse puller
Old Dec 24, 2012 | 05:32 PM
goalie35's Avatar
Thanks but there is no fuse for this in the panel. I also should have said I tested each removable fuse and they are all good.. What I should have asked is where can I find the fuse that powers the OBDII plug as it does not show active...
Old Dec 25, 2012 | 05:47 AM
Black3sr's Avatar
Hmmm under wty so let the dealer repair it.
Old Dec 25, 2012 | 06:09 AM
BlueCell's Avatar
Always check the major grounding points of the car. They are known to get loose and cause problems.
Old Dec 26, 2012 | 12:26 AM
goalie35's Avatar
Thanks for the suggestions.. Let you know what I find out..
trashercan
Aug 28, 2015 02:13 AM
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
setter11
Jun 12, 2010 02:38 PM
setter11
Jan 4, 2009 12:46 AM
