What u say about : 185-55-16
Old Jan 30, 2013 | 05:00 PM
honda junkie's Avatar
i have jazz 2012 , 1.2 MT , origal seze 175-65-15 , Wanna change for something bigger
Old Jan 30, 2013 | 05:20 PM
Wanderer.'s Avatar
I say that 185-55-16 is stock tire size here in the U.S. so go ahead and use that if you want. With 30 less hp (1.2L) than our 1.5L I don't think you'd benefit much from the wider (and heavier) 205-50-16 that a lot of us U.S. guys are running instead of the stock size.
Old Jan 31, 2013 | 02:15 PM
mahout's Avatar
Bigger? or wider?
Bigger tires will loweer your mpg's because the engine has to work harder to turn tires tht are farghter from the axle.
Wider is a good choice and idf you are careful it will increase your handling with little effect on your mpg's or acceleratiion.
205/55x15's sounds like a good choice to start (They make that? )
good luck.
Old Feb 15, 2013 | 05:55 PM
Cmonster's Avatar
tire size
Ok , so BEST ( All season ) tire size for a 2009 Sport ?
I have 185/55/16 now , but want more .
Old Feb 15, 2013 | 06:25 PM
mahout's Avatar
More what? cornering, longer tread life?, best wet or snow? fastest lap times?
Those all have different answers.
speed: 205/45x16 tires, with best lap times at tirerack test results
tread life: 205/50x16 with UTOG of 700 or more; maybe 600+
least cost: scour the internet for best price on tires above, including 185/55x16.
Thats before deciding if you are lowering or changing wheel sizes. Or offset for wider stance.
yeah, its a bit complicated. And needs considerable research.
Old Feb 15, 2013 | 06:36 PM
mahout's Avatar
Wider tires? bigger diameter wheels? wider stance?
With 1200cc's You probably shouldn't exceed 195 width and since you're original diameter tire is 23.95" I'd check on 195/55x15 tires, if they are available. Those are a trifle less diameter but are heavier so the lesser diameter will mostly overcome the weight penalty and have negligible affect on mpg's. If you want a different wheel hold to minimum 45mm offset (which widens your stance by about 14mm) and you can go with 195/40x17 tires on 17" wheels or 195/50x16 tires on 16" wheels.
good luck.
Old Feb 16, 2013 | 05:00 AM
Cmonster's Avatar
tire size
Thanks .... I guess I am most concerned about ride comfort / cornering / ride quality . Do not want to buy new wheels , just tires ... so will use stock s on my 2009 Sport .
Old Feb 16, 2013 | 05:27 AM
OpalArmes's Avatar
185-55-16 could be used for it just move on and grab the best collection of tire for your vehicle
Old Feb 16, 2013 | 05:43 AM
Cmonster's Avatar
tire size
Thanks ... what about moving up to 195 / 205 ?
Old Feb 16, 2013 | 09:11 AM
xpwex's Avatar
195 would be best bet
bulldogtrekker
18
Apr 13, 2017 12:40 PM
Darren Lund
May 18, 2012 01:54 PM
Fitcious
20
May 7, 2011 01:03 AM
ru4real
Oct 13, 2010 06:25 PM
ThEvil0nE
Jul 24, 2010 12:22 PM
