What kind of repairs to your Fit have you had to make?
Not really a repair, found out how sensitive the Fit's computer is, I had removed the air filter cover to get access to an emergency brake
cable for my toad, got sidetracked, closed the hood and next day when I tried to drive it, would start and only move a few feet before
stalling, then I remembered my previous days work, opened hood, replaced the cover and it was fixed.
5 years, 135k.
Umm, regular maintenance, and recalls/TSB's, and the drivers side tail light( shopping cart) along with repainting the quarter panel in front of it(again shopping cart), the quarter panel needs repainted because of the half ass job they did, I refused to pay or let them "fix" it.
She's all OEM factory, aside from brakes, tires, plugs, filters and DS tail light.
'08 A/T @ 70k+ miles, normal maintenance stuff other than a 3rd gear solenoid sw (A/T)
At how many miles?
Per maintenance schedule
Did your warranty cover it?
Bought used, no coverage other than TSBs
Any common issues that come along with the Fit?
Tend to frown when accelerating
then smile when filling up at the gas station or loading up stuff in the car.
At how many miles?
Haha yes! I just filled my tank for the first time on Sunday night. Only spent 30 bucks! So stoked! Vs. spending close to 60 with my 2000 Accord V6.
Ha, I'm the same boat. My first fillup was 29 bucks. Much easier on the wallet than either of my Camaros. The money I save on gas puts a huge dent in that car payment.
My '09 is coming up to 100k. Driver's side door got caught in the Newfoundland wind leading to an expensive repair. The car also burns 2 quarts of oil every 10k. Fog lights were bashed out in the first year and remain that way (AC condenser is protected by gutter guard). Other than these and two sets of tires, 3 engine air filters, about 6 cabin air filters, 4 sets of wiper inserts, and the LMS recall, all's been just fine. Oh, and two windshields. I'll have them change the plugs, coolant, brake fluid and pads next major service.
TPMS is very sensitive, check your tire pressure...you shouldn't need to go to the dealer.
Just make sure your'e between 34-36 PSI I believe.
Sometimes the PSI will fluctuate depending on the temperature as well.
