ECU interchangeability
Old Jul 31, 2013 | 11:50 PM
fit_racer's Avatar
Does anyone knows if 08 Fit's ECU interchangeable betweeen different markets. Such as USDM to CDM to JDM?
Since proflash only support USDM and CDM, I might need to get a stock USDM ECU for the proflash.
BTW, I have plugged a EP3 ECU in my GD3. It starts, redlined at 8.5K, but doesn't run very well.
Old Aug 1, 2013 | 01:28 AM
loudbang's Avatar
Short answer is NO. Long answer you would need to change the whole dash module also. There are some threads on this from people doing engine swaps and changing to the other market dash for the "Look".
Old Aug 1, 2013 | 03:53 AM
fit_racer's Avatar
Thanks man.
What if I change the USDM cluster to with the USDM ECU?
Old Aug 2, 2013 | 01:37 AM
loudbang's Avatar
Yep that will work. I think member kelsodeez was one of the guys that made the swap backward to use a JDM dash set. Maybe you could check his posts for it.
Garage R
Aug 4, 2025 09:39 PM
arnshrty
May 21, 2012 11:42 PM
jazzista
European Fit Forums & Clubs
Oct 7, 2011 04:06 AM
Fit Is Go
May 10, 2007 02:12 PM
George02
Mar 20, 2007 02:02 PM
