Bilstein B14 (PSS) on GD3, why not?
Old Sep 17, 2013 | 05:21 PM
Gesture's Avatar
Why will the Bilstein B14 (PSS) PN:47-165854 not fit on a 2007 GD3 Fit? Why is this a bad idea, or is it? If GD3 Mugen parts will fit on a GE8 then why not the other way around?
https://www.fitfreak.net/forums/2nd-...nsion-ge8.html
Old Sep 18, 2013 | 03:49 PM
Gesture's Avatar
Was it something I said? Around 70 view and no reply. Should I post this somewhere else?
Old Sep 18, 2013 | 04:00 PM
TPColgett's Avatar
I doubt many folks here can answer your question.
From all my suspension playing around on both cars, here is what I am confident in.
The rears will fit, should be bolt right in. You WILL have to fairly drastically cut or have very small bump stops as a GE shock will be longer, and will have less effective travel on the GD.
In the front.... these use a silly screw on zip tie to secure the senors for the brakes, so that should not be an issue. I can not confirm they will slip right onto the GD3 knuckle though. I know of at least one case where a GE based coil over required some work to fit the GD front as far as clearance for the mounting ears.
Also, this will be a fairly "soft" setup for a GD. The dampers will not be adjustable, and the valving in the dampers and spring rates were based on a heavier and stiffer chassis...
So, let me ask you, what are you trying to accomplish with this suspension? There are a lot of coil over/suspension combo setups for $1300 or so...
Old Sep 18, 2013 | 04:25 PM
Gesture's Avatar
I am planning to replace the stock shocks and springs. I want just a little stiffer for my daily commute and I wouldn't complain if it were just 1" lower. I have spent several days looking at oem replacement shocks and stiffer springs (Swift or other), I also looked at the coil overs available.
I know the GD has higher spring rates (168F/314R) than the GE stock (129F/117R) because of the softer chassis but the Bilsteins should be a higher rate than the stock GD springs. I know the rear rate is a big differential but I thought the GE8 came with rear sway bar? Even if it didn't I have been running the Progressive Rear Sway bar for a few years now, which should help to stiffen up the rear.
I am mostly concerned with the shock lengths and front upper spring perches.
Old Sep 18, 2013 | 04:41 PM
TPColgett's Avatar
Upper spring perch is a non issue, you will have to re use your GD stuff and that is all good to go.
Shock length, as I said, will be longer at least. When it comes to the Koni's that are out there from Redshift, they extend a full inch further than a stock GD would, but compress to an identical length as stock. So, in the rear this is a non issue unless you regularly have the rear of the car suspended higher than a foot or so above the ground. In the fronts... I have no idea. And again, without actually having the units hands on to measure, there is no way to confirm.
Have you considered getting a set of the Tokico HTS adjustable struts and either Ground Control coil over sleeves or a used set of Swift lowering springs? Hootie JUST did it with the GC sleeves IIRC with very positive reviews, and I believe there were a set HTS/D Spec struts in the classifieds on here...
If I had to do it over, or was no longer so seriously racing my GD, I would do the Tokico/GC combo in heart beat. I had Tokico's and Swifts, and of the 7 or so suspension setups and combos I have run on my GD, it was by FAR my favorite. Simple to dial in, not too low, MUCH better handling. With a proper alignment and some good rubber, really made the Fit fun!!!
Old Sep 18, 2013 | 05:42 PM
Gesture's Avatar
I appreciate your input, I had not considered the Tokicos. I quickly looked at the price and they are retailing for around $1000 and I will still need springs, $200-$300. I am tempted because I know this will be a more versatile setup but it would cost more than the Bilsteins.
I have seen you AutoXed your Fit with the Tokico and I assume the Swift springs? I AutoX a BMW e30 on Bilsteins and have enjoyed them. I guess that is the only reason I still feel a little draw to the bilsteins, I trust them.
Wanderer.'s Avatar
Yes I believe the question here shold be "why" not "why not".
If I had a GD I would do HTS + Swifts and never look back if it was a DD.
Old Sep 18, 2013 | 06:04 PM
I think you want the J's/Showa spring/shock package.
Perfect for a daily IMO.
Old Sep 18, 2013 | 07:23 PM
TPColgett's Avatar
I totally trust Bilstiens. Just installed a full set on my Mom's '68 Bentley
I had VERY good luck and development on the HTS/Swift combo for casual AutoX. Dial it stiff to compete, dial it soft for the ride home and to minimize complaints from the GF
There is a set of HTS rear shocks in the classified here for cheap:
https://www.fitfreak.net/forums/sale...-shocks-2.html
Which would save you a few bucks over the full shock purchase!
True story... Wish in a way I had never traded mine away for my S2's
There is a Spoon sports fixed package too out there somewhere isn't there? All of those are excellent options... but probably even more than the $1200 or so the OP was looking at once shipped over aren't they?
Old Sep 18, 2013 | 07:29 PM
Old Sep 18, 2013 | 08:49 PM
TPColgett's Avatar
Those look neato! Not a bad price... Hmm,
"Note:For North American models, JDM Honda stock stabilizer link ($33.00 x2) is required for the installment due to the geometry difference"
And looking at the pics, that is gonna be a must as that end link bracket is for sure different than the USDM ones:
Not sure how to easily get JDM OEM Honda bit's other than Rakuten or such, thinking with shipping... prbbly still $1200
Either way, those are COOL!!!
Old Sep 18, 2013 | 09:14 PM
kylerwho's Avatar
spoon fed
I can get the j's suspension along with the jdm endlinks in one package.
Old Sep 20, 2013 | 12:06 AM
Gesture's Avatar
I am going with the HTS and Swift combo. After a lot of searching I will be able to get the HTS and Swift for just less than the Bilstein kit.
Old Sep 24, 2013 | 01:02 AM
feared's Avatar
co-sign on the j's racing showa suspension. perfect for daily.
Old Sep 24, 2013 | 03:56 AM
xxryu139xx's Avatar
some guy here named vinzchan knows a jsracing dealer. maybe message him?
Old Sep 24, 2013 | 11:00 AM
Kylerwho above can get them for you.
Buy from him, he's an FF.net OG and all around cool dude.
Old Sep 24, 2013 | 12:22 PM
Wanderer.'s Avatar
Showa makes J's setup?
What's the difference between the regular Showa setup and the J's?
Old Sep 24, 2013 | 12:46 PM
Showa makes the shock/spring setup. Crux does the mega baller adjustable setup. It's the best thing ever.
Old Sep 24, 2013 | 01:31 PM
Wanderer.'s Avatar
Are the shock/spring setups marketed as "J's" and the one sold as "Showa" identical? There's a price break to be had possibly if so.
That J's Crux thingamabob looks awesome... even their shocks (only) are $3k
I can see why though, there's a lot of work that goes into them
ŠJ”*E»ìH’ö
^prepare for Google Japlish translations if you can't read Japanese
Old Sep 24, 2013 | 01:48 PM
Trust me, Crux jams are incredible.
