FS: LED Light Kit For 2009-2013 Brand New
Old Dec 3, 2013 | 03:33 PM
1SickVeilsideZ's Avatar
Hey guys I have a few LED / SMD kits available from a little testing I was doing.
The kits are all brand new as they are the extras I have left over from doing my car.
The kits will include the following items:
2X LED map lights
1X 48 SMD LED board for the dome
1X 15 SMD LED board for the cargo area
2X LED license plate bulbs.
Not the best pics, but you get the idea. They illuminate way better then the stock lights.
$29 Shipped for Sport Model With Map Lights
$24 Shipped for Base Model With NO Map Lights
Let me know, thanks guys!
Old Dec 4, 2013 | 05:27 AM
onefreshfit's Avatar
UUUUUHHHHHHH you could of blurred out my plates you know!!!!!!!!!!!!!!!!!!
Old Dec 4, 2013 | 09:12 AM
For what? No one wants your stock $hit
Old Dec 4, 2013 | 09:35 AM
connor55's Avatar
Would you sell just the cargo and plate lights?
Old Dec 4, 2013 | 09:55 AM
^^ PM sent
Old Dec 5, 2013 | 07:50 AM
Old Dec 5, 2013 | 03:36 PM
Wanderer.'s Avatar
Bump for good seller, quick shipping
Old Dec 6, 2013 | 02:06 AM
ZiaMan's Avatar
will this work for the GD? If so, how much for just the cargo light and plate lights shipped to 90701?
Old Dec 6, 2013 | 02:20 AM
Thanks! Glad you got them right away!
Yes they will work for the GD no problem. PM sent
Old Dec 6, 2013 | 08:58 AM
Ernesto12's Avatar
I need everything but license plate lights. Shipped to 93263?
Old Dec 6, 2013 | 09:29 PM
cjecpa's Avatar
Got mine today and installed (except license plate too dark to try) thanks for quick shipment.
Old Dec 16, 2013 | 07:22 PM
connor55's Avatar
just got mine today, having trouble fitting the cargo light in behind the plastic clear part.
its a 5x3 board of leds, is there a chance you sent me the wrong piece?
Old Dec 16, 2013 | 08:09 PM
Wanderer.'s Avatar
I figure you got it from your other post but yeah kind of have to finagle that thing in there it's a tight fit but solid once it's in.
Old Dec 16, 2013 | 08:24 PM
connor55's Avatar
Hmm still haven't gotten it yet, maybe I'm just not seeing how it can fit in or my housing is shaped differently somehow.
Here's a pic, there are plastic "walls" in the way that are narrower than the board itself.
Old Dec 16, 2013 | 08:33 PM
Wanderer.'s Avatar
Ah, I didn't even take the plug out. Just take the adhesive backing off, shove the led panel in the hole and position it square and put the cover on. The cover will keep it from moving. I was skeptical that it'd stay in place and not unplug itself but it hasn't moved at all.
Old Dec 16, 2013 | 08:41 PM
It should fit in there, it'll be a little snug, but it works. I've installed them on about 6-7 GE and GD with no issues.
The reason I went with this size board was to get maximum use of the cargo light. Let me know if you're still having troubles.
Old Dec 16, 2013 | 08:53 PM
connor55's Avatar
I found this video, and at 5:03 it shows the housing this guy has a with a similar board to mine.
So I realized that my housing is actually shaped differently. Look closely at my pic, the plastic walls are a full 1/4 inch narrower than the board. The walls also don't have any space under them for me to slide the board under. I might have to do some cutting,. Guess for some reason honda made different design for this housing?!
Old Dec 16, 2013 | 08:57 PM
Just remembered your fit is Canadian correct? That cargo lense might be different for some reason? Now that I think about it I don't remember seeing those little plastic walls like in the pic you posted.
I'll check mine out when I get home. Sorry for the inconvenience. We'll figure this out though.
Old Dec 16, 2013 | 09:01 PM
connor55's Avatar
Yeah it's a Canadian one. It's 99% the same as the usdm but for some reason they decided to change something small like this lol.
No worries man, I'm just checking that I got the right piece. I don't mind cutting those walls out to make it fit. It's not like I'm gunna need to go back to the stock light
Old Dec 28, 2013 | 02:57 AM
Still have enough for 1 kit or I can piece out if need be. Let me know guys, thanks.
