NYC FS 2009 Honda Fit 175k No Reserve on ebay
Old Feb 9, 2014 | 04:48 PM
MiMi1's Avatar
My beloved Honda is for sale
2009 Honda Fit No Reserve Original Owner Full Service History | eBay
Up for sale is my PERSONAL Honda Fit which I bought brand new in on Jan 20th 2009 from Bay Ridge Honda in Brooklyn.
I am the original owner of the vehicle. Carfax and AutoCheck show two owners but that was me registering it in Florida after I
had it up in NY for a year or two.
I have used this car to commute between Florida and NYC and have used it to travel for work purposes in the NY Metro area.
Currently it just rolled over 175k miles. I have just put on new tires, new rear shocks, detailed it and it is ready to go to a new
owner. Reason for sale is I am tired of driving stick in NYC. I don't do as much traveling between Florida and NY as I used to
and have since purchased an automatic Volvo.
All options work 100% no hiccups or issues drives very well.
Pre-wired for Sirius.
I have never used any aftermarket parts in any of my personal cars. All replacement parts and maintenance items were purchased
at OEM Honda Parts & Honda Accessories - Bernardi Honda Parts and Accessories. All fluids always done at the Honda Dealer, either Bay Ridge Honda in Brooklyn or Paul Miller Honda
of West Caldwell NJ. Bulk of the wear item work was done at the Dealer save for brake changes, clutch job, tires, filters, AC
compressor those items I did myself. Just sprayed the front and rear bumpers to get rid of any minor parking imperfections that the
car has accumulated over the years so they are virtually flawless. Few scratches and dents are to be expected here and there.
Prior to 85k just fluids were changed and it is all documented in the OE Honda Maintenance Record book that is inside the vehicle.
85k new thermostat water pump serpentine belt ... preventive
95k Struts replaced under extended warranty
95k One caliper seized
105k spark plugs preventive
126k All fluids trans, brake, clutch line, coolant
127k Clutch
130k Battery replaced with OEM unit
150k All fluids trans, brake, clutch line, coolant
160k A/C compressor
172k New front bearing both sides
173k Axle shaft seal drivers side, Trans flush as well
175k New rear shocks
175k New tires all around
Keep in Mind I have done OLD SCHOOL MAINTENANCE
4000 mile oil and filter changes
Every 25k trans fluid, brake fluid, clutch line, coolant
Every 15k cabin and air filter
It never let me down always started hot cold ... trips to Florida etc.
85% highway miles obviously. Lots of time on I95.
Pics on ebay.
Mike
Old Feb 9, 2014 | 09:03 PM
ALwAyS4SaLe's Avatar
Do you know what kind of tires you replaced it with... Also, Do you kow if timing belt and waterpump was replaced?
Old Feb 10, 2014 | 09:41 AM
MiMi1's Avatar
Tires General Altimax HP all around from tire rack
Thermostat, waterpump, serpentine belt done at 85k. This engine is driven by a chain so no timing belt.
Taffeta Fit
Aug 25, 2009 10:58 PM
segun
Feb 15, 2009 06:30 PM
Iluvmyfitsportnavi
Nov 1, 2008 12:26 AM
