Does y'alls right wiper arm vibrate?
Old Mar 14, 2014 | 10:00 PM
Threw_A_Fit's Avatar
2012 Fit Sport has 33k on the clock so far, running perfectly, no problems at all. The one minor pet peeve I have, though, is that since day 1, the passenger wiper blade arm vibrates like crazy at idle... it's becoming quite distracting. Wondering if any y'all did any DIY to it or even have the problem to begin with.
Thanks!
Old Mar 14, 2014 | 10:11 PM
carboy's Avatar
I've seen mine do that a few times.
Thanks!
Old Mar 14, 2014 | 10:13 PM
Thanks... I'm talking every time at idle... it's almost like the revs are the perfect harmonic resonance for the blade...
looks like these two guys dancing next to me when i'm driving....
Old Mar 14, 2014 | 11:32 PM
nukeme70's Avatar
Whenever I notice mine shaking like that, I just blip the wiper so it cycles 1 time, and usually it'll settle down after that.
You could zip-tie a washer or some other weight to change the harmonic...might work.
(edited to appreciate that I just noticed I have a 5yr member badge!)
Old Mar 14, 2014 | 11:34 PM
That's a good idea, I'd just be worried about a weight jiggling off and cracking the windscreen.
Old Mar 14, 2014 | 11:52 PM
kered424's Avatar
Yes, mine does that ALL the time, but it doesn't bother me that much.. Putting the car in neutral helps sometimes.
Old Mar 14, 2014 | 11:59 PM
Thanks, I'll try messin' around w/ it and let you know if I find an easy fix!
Old Mar 15, 2014 | 12:07 AM
Actually, looking at it right quick, it seems like maybe the spring... I'll try playing around with it in the morning and post pics when it's lighter.
Old Mar 15, 2014 | 12:12 AM
connor55's Avatar
is it just vibrating or does it also buzz against the plastic on the edge of the windsheild?
in either case you could try loosening the wiper bolt on the rubber cap and adjust it up or down slightly to get it to rest in a tighter position. dont want to move it too far off its original position though.
did this with mine and it made the vibrating go down a bit.
Old Mar 15, 2014 | 02:35 AM
jondotcom's Avatar
Seriously?
ARE YOU SURE the wiper is actually vibrating, or are you saying it appears to vibrate due to the curve of the glass and heat rising?
I think you need to put the car in park and look from outside of the car, because if I'm not mistaken, it just looks like it's vibrating, but it's actually an optical illusion. I'm not kidding...seriously LOL.
Old Mar 15, 2014 | 05:48 AM
Black3sr's Avatar
The wiper is not vibrating it is the car underneath it that is.
Geez a vibrator that does not need batteries
Serious, mMaybe bend the wiper arm down a bit to increase tension.
Old Mar 15, 2014 | 07:08 AM
Goobers's Avatar
Thanks!
Considering I only notice it when I'm stopped... I don't really consider it distracting.
All I can beyond that is... maybe you should just learn to ignore it.
Old Mar 17, 2014 | 12:45 PM
FitStir's Avatar
I didn't have this problem until I got that damn LMS recall done. Service dept really botched that one up for me, I even told them about it and they adjusted to make it worse. I noticed it doesn't always vibrate, but when it does it's annoying.
Gonna look in to fixing it asap in the coming weeks.
^^^gonna try this.
Old Mar 18, 2014 | 10:45 AM
1Gr8GE8's Avatar
I have not experienced that yet. The only thing irritating is that both my driver and passenger doors started squeaking
Old Mar 18, 2014 | 10:57 AM
Wanderer.'s Avatar
My passenger's side wiper vibrates a ton with the A/C or defroster on because the motor idles a little more crappy and there must be some harmonic stuff going on. I just ignore it.
Old Mar 18, 2014 | 11:23 AM
dvleucsd's Avatar
ITS ALIIIIVEEEEEE....but yes. it does.
Old Mar 18, 2014 | 02:52 PM
neither on my 09 or 12...
Old Mar 18, 2014 | 09:06 PM
MrKeishii's Avatar
when I first bought the car couple weeks ago I have notice my right arm wiper blade to be vibrating, thought I was seeing things lol
Old Mar 18, 2014 | 11:21 PM
Jon H's Avatar
Yep vibrates. Have a list of things to be doing on my car and the wiper arm is low.
Old Mar 19, 2014 | 12:01 PM
WRCanuck's Avatar
Yes! Funny that you posted this. My wife and I noticed our Fit doing it the other day while stopped at a light.
