A/C not working kinda...
Old Jun 30, 2014 | 07:30 PM
NicktheEvil's Avatar
Ok, I have searched this forum for a similar problem and hoping for a solution but I couldn't find one. Sorry if this has been posted before.
I have an 07 Fit Sport. When the weather finally got nicer, I started to try to use the A/C again. But it never got cold. The blower is moving air just fine, the A/C light comes on when I push the button in. But just no cold air.
At first, I thought that I was out of freon ( or whatever they call it now ) but one day out of know where the A/C worked. It worked for about 40 minutes of a 1.5 hour drive. And when it worked it worked perfectly. So in my head at least I have ruled out a leak.
Then I thought loose belt, but I just had the alternator replaced with a new belt and it has been properly tensioned ( as far as I know ) and still no cold air.
When the A/C did work I would press the button and you could feel the compressor kick on. The car would actually lose a bit of power. When I push the button now that doesn't happen. Would the compressor kick on if there is no freon?
Anyway, i'm completely out of ideas. Any help on the subject would be greatly appreciated.
TL;DNR: A/C won't turn on. I'm pretty sure I've ruled out a leak in the freon and the belt shouldn't be slipping.
Old Jun 30, 2014 | 07:52 PM
DWils's Avatar
If you bought the extended 8 year/100000 mile warranty you might still be able to have it fixed under warranty if there is a Honda problem. If not, I'm sure the dealership wouldn't mind taking more of your money. Have you tried taking the Fit to an air conditioning place? It seems like where I live there is an air conditioning shop every two blocks.
Old Jun 30, 2014 | 10:35 PM
DrewE's Avatar
Since it seems to be working properly when the compressor cycles on, I think I would also suspect that there is adequate refrigerant in the system (although of course it's not entirely conclusive, at least not for me). It sounds to me as though the problem is rather that the car isn't turning on the compressor, or its electromagnetic clutch (that connects the compressor to the pulley when it's on) isn't working properly. It should be comparatively easy to verify the clutch's operation by observing if it is energized but not engaging.
If, on the other hand, the clutch is not being energized, perhaps there's some sensor in the A/C system that's broken or disconnected or something and causing the computer to not want to turn on the compressor. (There may also be a relay in the clutch circuit; you'd have to check a circuit diagram for that.)
At any rate, a decent A/C shop or dealer should be able to troubleshoot fairly easily, I'd think. Make sure you mention to them that the compressor doesn't seem to be turning on at all in general, but that the system cooled the one time it did turn on.
Old Jun 30, 2014 | 10:58 PM
Hootie's Avatar
Did you check your A/C relay or fuses? If I remember right sometimes the relay can tend to stick open/close or have a irregular intermittent contact when engaged.
Old Jul 1, 2014 | 12:41 AM
Previc93's Avatar
Make sure the ac compressor clutch is engaging when the ac is on.
Old Jul 1, 2014 | 03:23 AM
ikutoisahobo's Avatar
Having freon or not shouldn't affect the functioning of the compressor. Either the compressor is going out or there is something wrong with the relays and stuff that let it engage.
Old Jul 1, 2014 | 06:45 AM
@Dwils I bought the car used and it has over 100k miles, but thank you.
@DrewE I just moved to a new area, so I was hoping to at least know what was wrong with the car before I took it to an unfamiliar mechanic. But I may be out of options.
@Hootie I haven't checked relays. That will be my next move.
@previc93 I haven't checked that the compressor clutch is engaging because I don't know what to look for.
@ikutoisahobo I had that same thought initially which is why I didn't think it was a low freon problem. I know the compressor isn't kicking on because the car doesn't stagger when I turn on the A/C button
Old Jul 1, 2014 | 08:13 AM
Carbuff2's Avatar
Just throwing this out there:
Nobody has mentioned the air-mix doors inside the heater unit. Or, the coolant control valve.
In order to get really cold air from the A/C, the heater has to be cold (no warm coolant flowing through it). Haven't looked it up specifically on the Fit, but every Honda I've owned for the past 25 years has mixture doors (either controlled by a cable or servo motor) that blend hot & cold air (for when you want to clear the windows in humid conditions, as an example).
Additionally, when the TEMP control knob is turned all the way to COLD setting, the coolant valve to the heater is supposed to be turned off. If it isn't, you will not get the coldest A/C. The valve is usually on the firewall, in the engine compartment. (Hard to see on the Fit, I know)
That said, a characteristic of a SLIGHTLY low Freon charge is poor cooling around town, but adequate cooling on the highway.
If you don't know your way around A/C systems, take it to a shop to be checked out. Around here, several establishments are running A/C checkout "specials" for $60 - $90 USD.
Old Jul 1, 2014 | 10:37 AM
Previc93's Avatar
If the low and high side pressure are too low it tells the pcm not to allow the compressor on just fyi.
I worked at a honda dealer for a while and most on the things we did to the cars was the relays that were spoken of and compressors for clutch and coil issues. As the air door could cause this the likely hood is very slim.
Op sounds like you aren't familiar with the ac system of a car so I would just take it to a shop....
Old Jul 1, 2014 | 03:11 PM
hondafitgow's Avatar
Idk if your situation is exactly like mine but I too had issues with a/c (compressor turned on but no cold air or it stayed cold for a while then stopped after 20mins). Got my car serviced for compressor "clutch and coil" and now its working like brand new.. only downside is cost ($$). But thats just my experience.
Old Jul 1, 2014 | 04:53 PM
doctor J's Avatar
Please refer to this post for images and diagrams!
https://www.fitfreak.net/forums/1st-...voltmeter.html
First verify that the over temp switch, pressure, main a/c and blower switches are not open
Read entire procedure:
Remove glove box under tray to expose ECU
turn ignition ON
push on the a/c switch (or select defrost) on the instrument panel
Turn blower to low
Get high impedance voltmeter, turn to volts DC scale
Connect black probe to the good ground
Touch (connector E, cavity 28) of ecu with red probe
Read the voltage and report!!!
A connector is shown E is similar
Turn igntion and a/c off
Old Jul 9, 2014 | 07:12 PM
Doctor J, I will do this as soon as I have a free moment. It may not be until next week though. Work is killing me. I do appreciate all the help from everyone though.
Old Jul 10, 2014 | 06:35 AM
jazzista's Avatar
Me too, having a similar problem after a local shop tried unsuccesfully to recharge my A/C...
Old Jul 10, 2014 | 03:58 PM
doctor J's Avatar
At what RPMs did the shop measure the A/C pressures??
On my car the low side pressure looks perfect on idle (40-45 psi ambient 82 F, Fan on 4th speed) but goes down to 20 PSI at 1500 rpm (the engine speed per Mitchel manual) which is off the chart!
I am getting the manifold set to check low and high side pressures to eliminate any other causes
At best the system on my car lost some charge over 7 years (acceptable leak rate is 1 oz per year and fit holds only 14 oz)
hondafitgow
Jun 23, 2014 11:41 PM
nojjon
Apr 30, 2013 06:55 PM
Grayfox
Aug 25, 2012 08:22 PM
Tapiwa
May 13, 2011 09:47 PM
chilis trip
Jan 30, 2009 12:12 AM
