Question: L Gear Behavior on LX CVT
Old Jul 18, 2014 | 09:32 PM
eigenmeat's Avatar
Hey guys, as perspective LX CVT buyer, I have a question on how the "L" gear behave on CVT transmission.
Is the "L" gear on this FIT CVT dynamics ratio or fix ratio.
By dynamic ratio L "gear", I mean the computer will automatically adjust ratio enough so that your RPM is, say 4000 RPM or more, regardless of what speed you are going. So when you shift into L at 40MPH or 80MPH, you RPM will just go up to 4000RPM, and not blow up/red line in the case when you going 80MPH.
In my current 4-speed automatics Corolla, it has what I called the fix ratio "L" gear. When you shift into L at high speed, the transmission will do nothing until your speed is below the safety limited(ie. not beyond red line when the downshift occur).
Old Jul 19, 2014 | 09:52 AM
BMO's Avatar
BMO
On the EX, there is no L (or 1,2,or 3). But there is S for sport mode, which lets you use the paddle shifters to approximate a man trans. In S mode, if you redline, it will shift for you.
I'm not sure what the options are for the LX, since it doesn't come with paddle shifters. But, since it's a CVT, there's no physical gear for the trans to be put in, and since the behavior with the paddle shifters is for it to change when it's at high PRM, I can't imagine it wouldn't "shift" for you to protect itself.
F0NIX
Feb 24, 2018 10:32 PM
TRDYaris
Jun 5, 2015 02:32 PM
NotBlake
Feb 3, 2015 07:17 AM
eigenmeat
Oct 2, 2014 04:04 PM
Kostas
May 13, 2006 01:39 PM
