Fender modification for jdm front end fitment?
After speaking with a few friends who are experienced in a front end swap on the gd fit they mentioned that the fender brackets needed to be tweeked to allow for proper alignment. Does anyone know step by step generally what the process is so that I can pass the Info onto my body shop? Thanks
just want to let you know nothing fits from the JDM front even with the JDM rad support, fenders mounting get the JDM ones if u could, also get the JDM rebar mounting, JDM washer tank if you are running HID headlights, JDM hood hinge .......
my body man spent like 30 hours modding and fitting just to line up everything, luckly I got the JDM cut rad support with the fenders mounting tap
setter11
Apr 1, 2009 01:01 AM
