2015 Honda Fit OEM Wheel & Tire Specs
Old Sep 13, 2014 | 09:42 AM
stembridge's Avatar
Exclamation 2015 Honda Fit OEM Wheel & Tire Specs
If you have a (US market) EX or higher trim 2015 Fit (GK), your cast aluminum OEM wheels have the following specs:
16x6 size
4-100 bolt pattern
56.1 hub bore
+53 offset
OEM tire size is 185/55R16, and earlier cars seem to have come with Bridgestones (as did mine, with a build sequence in the 196-- range). Later cars seem to be coming with Firestone tires.
Adding a 20-25mm spacer to the rear wheels will bring them out nearly flush with the fender and is an inexpensive way to change the look of the car.
Someone with an LX is welcome to post the steel OEM 15" wheel/tire specs below, and if you have installed a set of aftermarket wheels on your car, please post your specs (all info listed above, please) and a pic or two.
es
Old Sep 13, 2014 | 02:39 PM
abeb's Avatar
In my country, the OEM tyre is Goodyear Excellence. Same size and rating. Adequate for all wet condition road.
Old Sep 13, 2014 | 07:44 PM
Hootie's Avatar
Could you double check your wheel offset? I could have sworn that I read +53mm offset on the GK5 EXs wheels I've seen in person.
Old Sep 13, 2014 | 08:38 PM
stembridge's Avatar
Will do. I should have paid attention to that when I pulled a wheel to get the width... I've had such a hard time finding all the specs, I wanted to put them in one place. Some of the info contradicts itself, and this might be one of those cases. Prob won't pull the wheel again until my aftermarket ones arrive this coming week.
EDIT - Went back through the pics I shot, and it turns out I took one of the markings on the back side - it does appear to be a 53mm offset, so I updated the info above and added the pic.
es
Old Sep 14, 2014 | 01:27 PM
Hootie's Avatar
Hey, no biggie. We all slip up from time to time. If memory serves me right, the GK has identical wheel/tire specs as the GE... if not the exact same. We had gotten a LX model in a couple of days ago but I never had got a chance to see look at what wheel and tire size they run yet. I do know that these one in particular came equipped with Firestone tires.
Old Sep 26, 2014 | 07:10 PM
stembridge's Avatar
Quick pic of my EX with 16x7 +40 wheels and 205/50R16 tires installed:
es
(cross-posted in several tire/wheel threads)
Old Sep 26, 2014 | 07:21 PM
JN2k108's Avatar
are the LX steelies the same but in 15 in?
4x100
56.1mm hub
15x6 +53et
Old Sep 26, 2014 | 07:38 PM
stembridge's Avatar
Not sure.... Someone with an LX will need to pull a wheel and confirm the offset.
es
Old Nov 2, 2014 | 09:53 AM
gavinleemcclure's Avatar
Yes, I just looked at mine .
4x100
56.1mm hub
15x6 +53et
Old Nov 7, 2014 | 02:35 PM
CMK-'s Avatar
This really should be a sticky. Thanks, stembridge. Now all we need is the wheel's weight. Did you keep your OEM alloys?
Old Nov 8, 2014 | 05:01 PM
Namae Kana's Avatar
'15 LX CVT has 15x6J PF 50 Fumagalli T5R 09 05 14 MEXICO F3150
That's what is stamped on the rims.
Old Nov 20, 2014 | 05:10 AM
SurfAndSand's Avatar
es
How's the fit of the wheel/tire combo? Any rubbing? How close to flush are you? Are you lowered at all?
Thanks!
Old Dec 18, 2014 | 09:05 PM
stembridge's Avatar
Not lowered, and if I hit a big whoopdedoo, the fronts will kiss the plastic fender liner briefly. More here.
es
Old Dec 18, 2014 | 09:06 PM
stembridge's Avatar
Sold 'em already...
es
Old Dec 20, 2014 | 02:24 PM
matt6's Avatar
Wheel size 2015 Honda Fit LX
I just took a picture of my wheel specifications:
15X6J
PF 50 (offset)
Fumagalli
T5R
10/07/14 Mexico
F3150
Old Dec 20, 2014 | 03:24 PM
matt6's Avatar
after market wheel and studded tire combo
I just ordered 185/60R-15 General Altimax Arctic with studs mounted on 15X6 black painted steel wheels from TireRack.com for $685.92 (including shipping)
The wheel offset on these basic steel wheels is 45. The Fit's stock 15 inch wheel offset is 50. According to my Honda dealership the 5mm difference isn't anything the worry about, the wheels will stick out slightly but won't be noticeable or cause any mechanical issues.
Old Dec 28, 2014 | 11:41 AM
Apexracing's Avatar
I ordered my 185/60/15 Michelin x-ice xi3's from discount tire, mounted to 15x6 steel wheels with a +41mm offset. They fit very well.Name:  IMG_2484.jpg
The front wheel is about flush, the rear could use a 10mm spacer to sit flush, but i'm not worried about it.
Old Jul 30, 2015 | 10:30 AM
bigbacon's Avatar
so matt did you end up with any issues with the 45 offset?
Old Nov 27, 2015 | 11:37 AM
Sam Tsai's Avatar
Got this installed early 2015.
Enkei RPF1 17×7J +43
Kumho Ecsta SPT KU31 205/45R17
Had no problem until I changed from Tein H-Tech springs to KYB Lowfer Sports Kit(Shock+Springs). The KYB kit is much more comfort and slight lower with 2 finger gap up front.
WILL RUB the front fender clip if driving over uneven surface at normal speed and I am not talking about pothole. So this setup is NOT recommended if you going change your suspension.
I think the stock offset +53 for GK is there for a reason.
I'm going to order new set of wheel soon. Which will be WORK EMOTION 11R 16×6.5J +52 and using stock tire size 185/55R16. One of the recommended size I found on work-wheels.co.jp for GK5.
Will upload pictures here again once I get them.
Picture shown are with Tein H-Tech springs.
Last edited by Sam Tsai; Dec 11, 2015 at 06:36 PM. Reason: Photos not showing with the new uploader
Old Dec 10, 2015 | 07:35 AM
Sam Tsai's Avatar
Here we go, arrived today, fitted today.
WORK EMOTION 11R 16×6.5J +52 with 185/55R16.
