Front Bumper Removel? Injen CAI Help
Old Oct 16, 2014 | 11:45 PM
FitMinister's Avatar
Got a new Cold Air Intake, from Injen. It says I need to remove the front bumper to fully install it. Anyone have one? Did you actually have to remove the front clip to do so?
Any DIY's out there for this? Any help would be appreciated.
Old Oct 17, 2014 | 10:13 AM
DWils's Avatar
1. Pop hood.
2. Unclip the four clips on top if the radiator.
3. Unscrew one Phillips screw under each wheelwell.
4. Unclip a bajillion clips under the front part (leading edge) of the bumper.
5. Pull gently on the right side of the bumper under the headlight (pull perpendicular to the car).
6. Repeat step 5 but on the left side.
7. Pull off bumper by holding onto the part above the radiator. Put somewhere that it won't get messed up.
There is probably a thread that explains it better than I did and that has pictures, but above is basically how you do it. If it takes you more than 5 minutes you're doing something wrong. Reinstall is just like removal but in reverse.
DA K Cudder
Jan 18, 2014 12:53 AM
wuggiewuggie
Feb 27, 2013 10:23 PM
smatts
27
Oct 9, 2007 02:46 PM
moondog
Mar 24, 2007 06:03 PM
dmxsoulja3
Sep 3, 2006 06:28 PM
