Dashboard Gauge Dimmer
Old Nov 21, 2014 | 11:22 PM
GotFitB13's Avatar
I test drove an EX this afternoon and compared many things to the '13 that we own. I was surprised to find that when I turned the odometer dial that nothing seemed to happen. I looked at the manual online and it says that that's how to adjust the brightness of the instrument cluster. Are there certain conditions when the brightness is adjustable? The manual mentions when the parking lights are on, is this treated differently than when the headlights are on or set to auto?
Old Nov 21, 2014 | 11:46 PM
DArkk's Avatar
It doesn't make a difference. When headlights are on you can adjust the dash brightness. I never had this problem.
Are you able to reset the trip mileage or cycle through trip miles, MPG and etc?
I am wondering something might be wrong with the odometer dial. Dealer should be able to fix that for you.
Old Nov 22, 2014 | 01:39 AM
DrewE's Avatar
Assuming it's like the GE8 models, you can only adjust the brightness when the headlights are actually on. When they are off, the panel lights are at full brightness and the other control backlights are off. As I recall the manual seemed to say that there was a separate adjustment for the lights off case, but that isn't in fact true in actual practice.
Old Nov 22, 2014 | 05:44 AM
rodney's Avatar
when i first got my ex, i fiddled with the dimmer. i ended up leaving it at one notch under full brightness.
a few weeks ago, i wanted to change it, and nothing happened. button dial did nothing. i am in IT, so i followed my own advice, and restarted the car... low and behold, it works again...
Old Nov 22, 2014 | 07:34 AM
Fitmo's Avatar
Where did you find the CTRL-ALT-DEL buttons?
Seriously, there are also some anomalies that can be fixed on modern cars by disconnecting the battery for a minute.
Old Nov 22, 2014 | 08:17 AM
rodney's Avatar
didn't need them, i remoted in via Citrix...
Old Nov 22, 2014 | 08:37 AM
Fitmo's Avatar
Well played, sir.
There are a couple of things I haven't had time to try yet…
one is to see if the EX head unit will recognize a USB soundcard as an AUX in. Soundcard is a base spec USB device that doesn't require a driver.
the other (and I seriously doubt it) is to see if it will recognize the USB Internet connection to my 4G/LTE mi-fi. At least it should charge it.
Old Nov 22, 2014 | 09:06 AM
Timbo Slice's Avatar
I leave the dimmer one click under full brightness, this way it auto dims the main screen when the lights turn on.
Old Nov 22, 2014 | 09:11 AM
GotFitB13's Avatar
Wonderful. I never thought I'd have a car that when there's a problem, if I were to call Honda Customer Support they would ask "Have you tried turning it off and on again?"
Old Nov 22, 2014 | 02:23 PM
NotBlake's Avatar
The dimmer only works when the headlights are on and it may only work when the ambient light sensor indicates that it's actually dark out.
Old Nov 22, 2014 | 02:50 PM
quikser's Avatar
gkitf16
May 7, 2014 07:03 PM
omgwtfbbqcopter
May 25, 2012 12:36 PM
AWDturbo
Aug 21, 2009 09:49 AM
hkjazz
theljnet.com
Jan 2, 2008 12:34 PM
Jimmy101
Jul 7, 2006 10:40 PM
