Camber Kit? Do I have to have one?
Old Dec 18, 2014 | 12:53 PM
FitMinister's Avatar
I just put in Tein S-Techs on my 2010 Sport, and need to get an alignment but a couple places have said I need a camber kit, is that true?
I always thought that caster/camber kits were needed with a 2 or more inch drop.
Any help?
Specifically people with S-Techs
Old Dec 18, 2014 | 01:31 PM
Wanderer.'s Avatar
No you don't NEED one. The Fit has Macpherson strut front suspension, and does not gain OR lose much camber with a drop.
They are beneficial for cornering, because the Fit has an inherently bad camber curve because of suspension design, but not required. I have been running S-Techs with no camber bolts for many, many miles.
I do have the bolts sitting in my garage, i'll install them when I put my new shocks in and get an alignment.
Old Dec 18, 2014 | 01:33 PM
De36's Avatar
Do you plan to track the car or auto-x?
Old Dec 18, 2014 | 01:38 PM
nope.
total side note....any way to add camber to the rear?
ive seen this for the front/rear...anyone tried this?
https://www.fitfreak.net/forums/2nd-...ber-cheap.html
Old Dec 18, 2014 | 01:52 PM
De36's Avatar
It wouldn't hurt to throw a set of crash bolt on the front and run 1 degree on the street.
You can not add camber to the rear without fabrication. The Spec V guys with a solid rear axle put the car on a frame puller and pull on the center on the rear beam (slightly bending the axle) to increase camber. There is not much of a need to increase the camber in the rear. The car has a difficult enough time rotating as is.
Old Dec 19, 2014 | 01:31 AM
ghettoboy247's Avatar
if you don't need more than 1.5 deg, just go with the honda accord camber bolts
Old Feb 12, 2017 | 01:11 PM
wattahouz's Avatar
so basically with a 1 inch drop for the the camber should still be fine?
whitefitsport
Oct 2, 2018 10:54 PM
kyobi
Jan 30, 2012 08:50 PM
Santiad
Aug 31, 2011 10:18 AM
Lil Blue
24
Jan 11, 2011 11:17 PM
FELIXY69
Jul 21, 2009 10:38 AM
