grinding noise !!!
Old May 9, 2015 | 05:08 AM
pentium77's Avatar
grinding noise !!!
Recently i notice some grinding sound when i m driving esp when the accelerator press and when during cruising,but once the accelerator is released the grinding sound gone,when i step on accelerator again to gain speed etc the sound is back again.what is the most likely cause.thanks.BTW my ride is GD1 manual,MTF changed,clutch changed
Old May 19, 2015 | 07:14 PM
john380's Avatar
Sounds like a loose heat shield or baffle in the muffler is loose.
Old May 21, 2015 | 02:20 PM
Doug Just Doug's Avatar
What john380 said was my first thought, too, particularly if the noise occurs mostly at certain rpms or engine load situations. If the noise also occurs when the trans is in neutral, then I guess you can eliminate the clutch as a source (a bad throw-out bearing is more of a "screech" sound I believe.)
nodelock
Oct 25, 2012 05:43 AM
ltd
Apr 30, 2012 06:51 PM
ltd
Apr 23, 2012 06:41 PM
runbikerun
Jan 23, 2009 04:56 AM
KentuckyFit
Jun 18, 2007 09:54 PM
