Fit headlight bulb size..!
Old May 21, 2015 | 04:22 AM
IQBALLK's Avatar
HI..
I thought my gp5 (2015 February) had H4 (9003) bulbs. bought pair of cree led h4's from ebay. but the stock bulb is different than h4. can any one pls confirm is this the head bulb..?
Old May 21, 2015 | 04:28 AM
IQBALLK's Avatar
stock bulb was SYLVANIA HB3 (9005) 2 PIN SINGLE BEAM YELLOW.
Old May 21, 2015 | 04:52 AM
Black3sr's Avatar
These sound like your signal lights.
Old May 21, 2015 | 06:37 AM
IQBALLK's Avatar
if it is.. wheres the head bulb located..
Old May 21, 2015 | 07:01 AM
Black3sr's Avatar
Is the one you took pic of behind the signal light or not? If so then the high and low ones are to the outside. Anything in your manual?
I did not realize you have separate high/low lights on the GK.
Old May 21, 2015 | 07:26 AM
Uncle Gary's Avatar
Wow, that's a bit different setup from the Fits we get here in the U.S. We just have a single headlamp on each side with a 9003 (H4) dual beam lamp.
Old May 21, 2015 | 08:14 AM
IQBALLK's Avatar
please check this pic..
Old May 21, 2015 | 11:25 PM
IQBALLK's Avatar
some more pics...
Old May 21, 2015 | 11:31 PM
IQBALLK's Avatar
Old May 22, 2015 | 04:05 AM
Black3sr's Avatar
Well that is interesting but does not help identifying which bulbs you need. If it is not in your manual then I would just call a dealer and ask them.
Old May 22, 2015 | 09:04 AM
xxryu139xx's Avatar
one of your pics is of a HID ballast i think. question is why replaced HID with LED?
Old Sep 6, 2023 | 11:23 PM
icyswish's Avatar
Any update on the bulb size of gp5 headlight low beam and high beam?
Old Sep 8, 2023 | 06:20 PM
Action Jackson's Avatar
You can remove them and look at what is printed on the bulb base.
Old Oct 17, 2023 | 09:43 AM
icyswish's Avatar
My main concern is i bought a pair of those projector headlights but i noticed that the right projector didnt have low beam drive unit, and i cant find one here in ph
Old Oct 27, 2024 | 09:55 PM
Fargham's Avatar
Any updates on the low and high beam bulbs?
Old Oct 29, 2024 | 12:26 PM
Rotcel16's Avatar
Low beam are D2s or D2r. High beam is h4 I guess
Old Oct 29, 2024 | 12:36 PM
Fargham's Avatar
Thanks a lot, and do you know if they can be changed or upgraded? H4 are easy but what the low beams they have an assembly behind them.
THE_DON
109
Aug 8, 2023 05:03 PM
mav238
Jan 14, 2015 02:59 PM
drock305
Feb 9, 2010 08:06 PM
713_fit
Oct 18, 2009 01:06 AM
urbnzeus
Jun 1, 2009 10:26 PM
