Back to stock bulbs
Old Jun 1, 2015 | 09:36 PM
CBerg20's Avatar
Back to stock bulbs
So I was changing my bulbs and noticed that the previous owner had a hid kit I stalled, do I simply removed the hid harness and figure out the stock wiring route ? My low beams work but high beams arent
Old Jun 4, 2015 | 11:52 AM
DWils's Avatar
Back to stock bulbs
So, the previous owner installed HIDs and you didn't notice? Weird, since they're way brighter than stock. As far as removing them all you have to do is, well, remove them! There shouldn't be any wiring harnesses that you should have to follow for the stock bulbs. The HIDs should have a harness leading from the positive terminal of the battery to eventually the left side headlight connector. There should also be a ground wire somewhere on that harness too.
13fit
Dec 30, 2012 12:37 PM
da-1510a
May 23, 2010 07:07 AM
sevenaprils
Apr 1, 2009 11:53 AM
307890
Aug 5, 2008 10:03 PM
sevenaprils
Jun 9, 2008 02:44 PM
