Tire pressure monitoring system?
Old Jun 22, 2015 | 02:29 AM
Soon2015FitWillBeMine's Avatar
This car is the first I ever had that comes with this somewhat annoying (according to my friend) feature. I have some questions. Will this system alert me if tire has too much air? I would like to go above the pressure that is recommended on the sticker in driver's door. Also, what happens if I rotate the wheels? Will it know which wheel is in which position? Does it care?
Old Jun 22, 2015 | 08:38 AM
Uncle Gary's Avatar
Unlike the TPMS system in the previous generation Fit. The GK (3rd gen) Fit uses the ABS sensor system to compare the rotational speed of the four tires to determine if a tire is low on air (low pressure=smaller effective diameter=higher rotational speed). There are no sensors in the tires.
Yes, changing the tire pressure (adding/releasing air) may set off the TPMS system, but it is a simple task to calibrate it (instructions are in the owner's manual), and you can do it yourself. I run my tires a couple of pounds over "recommended" with no trouble. The system is not looking for exact pressure, just difference in rolling diameter.
The nice part of this system is there are no expensive sensors in the wheels to fail. This means you can run different wheels (summer/winter) without having to buy extra sensors (and dealer calibration). The system will work with any wheels you put on. You'll have to calibrate it for the change, but, as I said, that's pretty easy.
Although it could, I don't think the TPMS system in this car is set up to alert you to WHICH tire is low.
Old Jun 22, 2015 | 09:07 AM
KikeDiaz's Avatar
What does the usa model come with wheel pressure? Mexican fit does not come with any security. It just came with two air bags and seat belts. Shm I begging to hate honda.
Old Jun 22, 2015 | 10:30 AM
robot's Avatar
There were a few times I got the pressure alert and found a slow leak in a tire due to a nail being stuck in it. So in those cases, it worked. Once I had a flat tire that I didn't see because it was late at work in the dark and I didn't notice the tire was flat until I tried to pull out. No warning because the tires didn't rotate yet. Recently I got an alert when I loaded up 3 other people for a ride on a warm day. I got out checked each tire for punctures and air pressure and all looked good. The front tires were reading 31 psi and the rear about 35. Got home and I filled the fronts to about 33 and the sensor still stayed on so I just reset it. It's not a perfect system but I still like it.
Old Jun 22, 2015 | 11:36 AM
Bassguitarist1985's Avatar
Id rather have a system that I can reset myself, than have the dealer reset because theres a problem with it.
As the saying goes, if the part (sensors in tires) isn't in the design, then that part will never fail you!
Old Jun 22, 2015 | 03:35 PM
Uncle Gary's Avatar
Tire pressure monitoring systems have been mandated in the US for new cars since 2008 courtesy of the federal government. That's why we get it and you don't. Apparently Mexico doesn't require it.
Don't blame Honda, blame different laws in different countries.
Old Jun 22, 2015 | 07:30 PM
Gorilla's Avatar
It's not the best system since it can't tell you which tire is low, but it does work. Had it save me a couple times where a slow puncture leak had reduced the pressure enough that you couldn't really feel it driving in a straight line but going too fast in a turn could lead to disaster if it weren't for the warning light telling you something is up. False positives are rare too.
Old Jun 22, 2015 | 09:57 PM
GeorgeL's Avatar
Mexico doesn't have as many tort lawyers as the US!
Old Jun 23, 2015 | 01:27 AM
KikeDiaz's Avatar
Cool
Well in not to blame Honda per se but mexican consumers and laws but indeed honda has a lot to blame.
The mexican model comes with any security. The only security it has is ABS and two air bags(frontal). It even comes with just one key in the lx model.
It lack of everything else like VSA, Hill Assist, ESA, EP, tire monitor(what I was not aware), Maintenance reminder, Breake assist, Back up camera with sensors. And they are not availble even though it has the same price and it is made in here.
Another annoyance is that it is required to change the oil every 3 miles if not you will lose the guarantee( as I am seeing there it goes up to 9 miles). That makes the maintenance cost pretty expensive.
The biggest complain is that they did not even recall the bumper problem in early models. International honda said that it was not requiere in the law so they did not do it.
But is not the only brand that does this, but being a reputable brand with loyal costumers this is a deal breaker. At least this vehicle is no seeing that much for this reason. We pay the same and we got less equipment and less security. Remember tacit airbag defect, here they did not change it even though it was a global problem.
That why not im looking for a mazada 2. It is the first honda I have ever own I like the oil consumption but being in a hard accident that almost killed me my first concern is the security.
Anyways, good to know honda USA is pretty good. Cheers for you all.
Old Jun 24, 2015 | 11:54 AM
Redd's Avatar
How much does a Fit cost in Mexico? I assume it's cheaper.
Old Jun 24, 2015 | 02:56 PM
KikeDiaz's Avatar
The lx model is around 210,000 pesos. The 1 dollar is 15.6 to 16 pesos. That make it around 13,000 dollars. It is like 2 grand less. But we do not pay destination fees, international duties, or anything related, It comes streigth form the factory.
Still pretty expensive compared to even bigger cars. And pretty expensive if you account that the minimum wage is 4 dollars a day.
BTW what do you think about the mazada 2?
Ron Belisle
23
Nov 3, 2021 04:40 PM
ECGETAWAY
Sep 21, 2010 11:11 PM
Len1
Sep 11, 2009 07:17 PM
jelliotlevy
Dec 19, 2008 09:25 PM
Evan_2k
Sep 2, 2008 07:39 PM
