How to install third-party keyless entry
Old Jul 2, 2015 | 07:26 PM
DataDroid's Avatar
Question How to install third-party keyless entry
I recently purchased
this keyless entry system this keyless entry system
since the driver-side lock cylinder on my 2007 base model no longer turns and it's a lot less expensive than the OEM part. However, I've never done any electrical work on my car before, so I'm not really sure where to start. I've removed the panels covering the fuse box and other wiring, including the ignition module.
This Amazon review This Amazon review
contains a picture of the included diagram, but without better knowledge of the Fit's wiring, it's not much help to me.
Old Jul 3, 2015 | 04:40 AM
Black3sr's Avatar
Doe $15 I doubt even if you got it working it would last very long. I expect there is no one on here that can understand those instructions. Bite the bullet and get original part.
Old Jul 3, 2015 | 06:31 AM
GolNat's Avatar
Looks like you need to find white/green and white/blue wire according to this:
http://www.the12volt.com/installbay/....asp?tid=84487
I used this site to wire up the keyless in my Civic and it was somewhat accurate. I still verified all my connections with a multimeter before hooking into them.
The locks are negative triggered so the module needs to send a (-) pulse to the door trigger.
I would throw that module away and get a better one IMO.
cuban8
Aug 15, 2018 09:13 AM
jpcerone
Jan 20, 2015 08:12 AM
ImUnFit
Jan 16, 2015 12:27 PM
Raziaar
Jun 28, 2014 01:54 PM
franceska
Feb 23, 2007 12:55 PM
