EGR Delete
Old May 13, 2016 | 12:37 PM
HermTDI's Avatar
EGR Delete
have the need to delete the EGR system (electronically).
Befor anyone starts raving ... This is for legitimate off-road diagnostic purposes only .. OK ?
My question is what are Fit DIY's using to pull & up-load your tuning files via OBD-2 port ?
Will the Kess V2 doggle kit work for ECU file swaps (Fit 2015) ?
V2.15 KESS V2 OBD Tuning Kit Master Version No Token Limitation Firmware V3.099
TIA
Herm
Old May 13, 2016 | 05:27 PM
kylerwho's Avatar
spoon fed
Most of us use hondata flashpro. takes all the guess work out of pulling code files.
Old May 13, 2016 | 06:05 PM
dwtaylorpdx's Avatar
TIA
Herm
Side note,, please document the effect of the change.. If you can Dyno it even sweeter.. So many do this and its all butt dyno and no real data.. I have my own suspicions but would love to see how it works out for someone else..
Old May 15, 2016 | 08:42 PM
Myxalplyx's Avatar
It had no affect on my 1/4 mile times from before and after removing the EGR pipe. At least my 1/4 mile times did not get worse. Then again, the pipe was removed due to a separate cat pipe being installed so 1/4 mile times improved. I would not say it improved due to the EGR pipe being removed though.
Old May 16, 2016 | 06:39 PM
Darn!
The world may never know.
HermTDI
May 13, 2016 12:14 PM
ThEvil0nE
Oct 15, 2011 03:09 AM
viperjh16
New York Community
Apr 5, 2011 12:08 PM
Frenchi169
New Jersey Community
Jan 1, 2011 01:02 PM
Sam Misled
Dec 2, 2008 08:25 PM
