Automatic: S Mode?
Old Aug 22, 2016 | 02:09 PM
yuffers's Avatar
Automatic: S Mode?
Just curious, does anyone just ever drive in S mode all the time instead of D?
Old Aug 22, 2016 | 03:30 PM
jhn's Avatar
jhn
60% S > 40% D
Or thereabout.
Old Aug 22, 2016 | 04:28 PM
Wdoney's Avatar
Never been in S mode. Drive in D
Old Aug 22, 2016 | 06:32 PM
Alco RS-1's Avatar
My young driver learned on a manual, so uses the S Mode in the same percentage jhn does. There's a very steep hill nearby and by shifting to 2nd, the Fit rides at a perfect speed downhill without touching the brake. I think the paddle shifters are a pretty cool feature.
Old Aug 22, 2016 | 11:17 PM
tbFit's Avatar
I flip it in to "S" mode when I'm merging onto the freeway and I want power on tap. Once I get settled in to a lane and speed of choice, I drop it down to "D" so I can hear myself think.
I will also use "S" anytime I need more instant response, such as going up variable pitch hills or when I want a little engine braking. For peace and quiet, back to "D".
Old Aug 23, 2016 | 03:00 AM
stembridge's Avatar
I'm probably 30% S (mostly with paddle shifting as opposed to full "auto"), and the rest D, since I have a 45-55 minute commute either on 55mph State roads or 70mph interstate.
I use the "downshift" paddle in D to engine brake probably 50% of the time.
If I'm in a longish underpass, it's 100% S mode, and wind it out, baby! Love to hear that vtec scream through the Tanabe Medallion Touring exhaust!
es
Old Aug 23, 2016 | 06:37 AM
exl500's Avatar
Same here.
Old Aug 23, 2016 | 07:54 AM
i found dat S mode without using the paddles works real well in congestion as it keeps the revs in 3k range, nice engine braking, and immediate torque (if u want to call it dat).
once traffic starts moving i shift it back into D.
Old Aug 23, 2016 | 11:29 AM
Buck Fitty's Avatar
I never use S any more, since using the paddles in D puts it into a "temporary S" mode. Any downshifting for passing, merging, or downhill engine braking, can be accomplished with the paddles in D mode. Maybe I'd try S on a very long downhill.
Old Aug 23, 2016 | 11:46 AM
stembridge's Avatar
So the *real* question I want to know is whether anyone's tried "S" and "Eco" modes at the same time! (c: Kind of think it might send you into a perpendicular universe!
es
Old Aug 23, 2016 | 01:08 PM
2Rismo2's Avatar
es
I've done it and S to me overrides ECO mode. I've tried S in ECO and non-ECO and to me it's the same performance. Though this may be Bizarro2Rismo2 typing...
I'd say I drive in S mode maybe 20% of the time. Mostly it's in D mode and I flip ECO on/off depending on the road I'm on. On my daily commute there are some long stretches that are flat and ECO is on. The hilly sections I keep ECO off as it wants to jump into higher RPMs more.
Old Aug 23, 2016 | 03:13 PM
stembridge's Avatar
When my wife drove a couple weeks ago, she made a comment about how touchy the throttle was (too fast!), so I told her to hit the ECO button, which solved the problem nicely.
I use ECO a lot in the winter in snow and ice, since it helps prevent wheel spin on starts.
es
Old Aug 23, 2016 | 05:25 PM
andre181's Avatar
es
Every day!
I recently moved about 20 miles out of town and have a 100% interstate commute to work.
I've found that S-paddle mode in locked in 7th "gear", with ECO on and cruise set (usually around 70 MPH) returned the highest MPG and still provides a good amount of power for passing without a ton of downshifting.
I'm now averaging about 45 MPG on the trip computer, and 43 MPG manually calculated.
Edit: I'm also using ethanol free premium which seems to be helping as well. Its only an extra $2/tank generally and I'm getting at least an extra 50-60 miles/tank since making that switch.
Old Aug 23, 2016 | 10:11 PM
tbFit's Avatar
Originally Posted by andre181
...I've found that S-paddle mode in locked in 7th "gear", with ECO on and cruise set (usually around 70 MPH) returned the highest MPG and still provides a good amount of power for passing without a ton of downshifting.
Good tips... I recently completed a 5 hr round trip trip and also found that "S" mode at speed yields a constant higher RPM. I suspect that will aid in passing which is my only issue with the CVT when it's snoozing quietly at 2500 RPM at 75mph.
Old Aug 24, 2016 | 06:54 AM
es
my wife only uses eco mode so when i drove the one week in s-mode it was in s-mode majority of the congested commute. 40.2 mpg
Old Aug 24, 2016 | 06:56 AM
es
huh, good tip. i should turn off dat eco mode when i get into the fit each and every time. i hate the sluggish starts. in s-mode (no paddles) the car responded more immediate though while in eco mode.
Old Aug 24, 2016 | 12:52 PM
gusvera's Avatar
That is exactly what I do, drive 100% of the time in "D" and use the paddles to downshift all the time.
Old Aug 24, 2016 | 01:32 PM
memo's Avatar
Never. I use D mode, when I go in a short downhill, hitting paddle shifter down does the job. However, I only have a year with my fit and I haven't take it to the mountains, which I probably do by the end of this year, I would use S w/o paddle uphill for more instant throttle responde and with paddle on downhill for long engine breaking.
Old Aug 24, 2016 | 08:53 PM
EdmonThom's Avatar
Just tried S mode
I've had my Fit for almost 2 years and never really bothered with Sport mode until last weekend. Vrrooom!
Old Aug 25, 2016 | 09:12 PM
Bossharp's Avatar
I put mine in S mode by accident coming back from a gig with my wife right after we got and she asked me what was wrong with the car. ..
