Turn signal plug/socket
Old Jan 28, 2017 | 12:09 AM
Freman's Avatar
Anyone know what kind of plug and socket this is and maybe where to buy it?
I'd like to get my hands on then to make a short splitter cable to avoid splicing.
Old May 14, 2017 | 01:38 PM
skatana's Avatar
If there is a wrecking yard where you can pull parts off a car, newer civics and accords will have the plugs and you can pull them off that. I pulled connectors off an '05 civic and an '01 civic to make my adapters.
Old May 14, 2017 | 04:47 PM
Freman's Avatar
Yeh, I've managed to get some tails (yay) and a parking light socket. I've not been able to find the sockets for indicators, I have some but they don't fit. Not many jazzes go to wreckers it seems. I'll try civics
Old May 15, 2017 | 12:35 AM
Freman's Avatar
Whelp, called every wrecker in 100km, seems Honda's either don't often end up in crashes or insurers aren't giving up the car...
car...
Not sure where to look now
Old May 15, 2017 | 12:54 AM
skatana's Avatar
Damn. The 3-pin indicator connector part number is 04321-S5A-306 in the US. I DON't think it'll have any pins in it, but a 5 pack should be less than $6.00 USD. The 3-pin indicator socket is part number 33303-TR0-A01. Again these are the US models, but from the pic you posted, they look identical.
Old May 15, 2017 | 12:58 AM
Freman's Avatar
hmm mine are only 2 pins, I got some that look almost identical but the catch is slightly wider and the pins are upside down.
I'll pull one out when. I get home and take better pics and record all the numbers/markings.
Old May 15, 2017 | 02:48 AM
Freman's Avatar
This is it
Old May 15, 2017 | 05:31 PM
skatana's Avatar
Do you have a pic of the other side? Of the socket locks match the US versions, I'll try to pull you some the next time I head to the wreckers and ship them to you.
Old May 17, 2017 | 08:25 AM
Freman's Avatar
My friend, that would make my day.
This is the front side of that connector (Stanley Amber 159 on flat)
This is the only connector I've been able to find here (Stanley 10800 Amber on socket) and it doesn't fit, the catch is wider on the ones in my car and the pins are further from the catch. And i have an extra protrusion of plastic on the bottom
Old May 17, 2017 | 03:36 PM
skatana's Avatar
They look very similar on the lock side. I'll have to wait until family gets home with my Fit to cross check them. It'll be a 3-pin socket so you might need to use a different bulb (7443 or 7442), but I'll pull 2-pin blinker sockets and 3-pin wiring and connectors too, so you can make adapters.
Old May 18, 2017 | 06:32 PM
koolkevin1107's Avatar
It'll take you 20 minutes to cut, splice, solder, heat shrink, and wrap the cable for the longer length. It's taking you 5 months to find an adapter that you'd still have to cut, splice, solder, heat shrink, and wrap lol.
Old May 18, 2017 | 06:46 PM
Freman's Avatar
yep, all this to avoid splicing the original wiring...
Old May 19, 2017 | 02:15 AM
Freman's Avatar
So, the part number is 33302T2A003, they cost $10.21 each, and I'll have them in 2 weeks.
In the mean time for the LOLs, I'm going to cast my own
Old May 19, 2017 | 11:04 AM
skatana's Avatar
I'm the same way. Took 8 months to gather all my parts for adapters, but I like the ease of being able to instantly change it back to stock with no splicing.
Old May 19, 2017 | 11:07 AM
skatana's Avatar
Nice. Let me know how they turn out.
Old May 20, 2017 | 10:48 AM
Jack Hammer's Avatar
I bought some adapters off eBay to use with the resistance units that went in between the socket and harness but didn't like the heat from the units so I shelved the project for now. I think they were around $5 ea.
Triskelion
Sep 23, 2022 02:58 AM
Carl Gerhold
Dec 13, 2020 11:10 PM
mxl180
Jul 14, 2012 07:42 PM
mxl180
Aug 2, 2010 09:25 PM
sLiVeRwOrM
Oct 25, 2007 02:22 PM
