Replace cupholder light? (lights right under climate control)
Old Feb 23, 2017 | 07:54 PM
Metadata's Avatar
Hello, is there an easy way to replace the two lights right below the climate control? I removed the one screw and pulled the plastic off under the climate controls, only to see that the bulbs are INSIDE of the climate control unit and shine through two small holes.
Old Feb 23, 2017 | 11:44 PM
geopat's Avatar
there a pain. You need to pull the whole radio assembly out to get to them.
Old Feb 23, 2017 | 11:50 PM
Metadata's Avatar
Looked up on how to remove the radio, and that part seems easy.
Do you know if getting to the bulbs themselves is easy once the radio is pulled out?
The OCD in my wants to replace the burn out one!
Old Feb 24, 2017 | 10:11 PM
geopat's Avatar
Its not bad Iv had my radio out a couple of times now it's just awkward. I learnt from experience to unplug the fan switch before pulling the housing out. It would seem easier to do it after but there is very little slack in the wiring and I snapped the back off the switch.
Once its out the bulbs are a 5 min job. I swapped in leds when I replaced my radio.
Old Feb 24, 2017 | 10:21 PM
Metadata's Avatar
Awesome. Any chance you remember the bulb code so I can buy it ahead of time?
Thanks for the information. It sounds a lot easier than it looks!
Old Feb 26, 2017 | 11:32 AM
geopat's Avatar
They are a T5 bulb
Old Oct 4, 2018 | 03:05 AM
silence911's Avatar
How many bulbs are there to replace? I'm looking to open up my radio assembly soon
SaukRapids
Jun 14, 2018 03:54 AM
Santiad
Jul 3, 2016 10:29 AM
djas51
Mar 29, 2016 06:39 PM
Jazzyfizzle
Sep 14, 2008 09:17 PM
Arctic Wolf
May 4, 2005 11:16 AM
