3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
‘15 rear shocks
Old Oct 24, 2017 | 10:39 AM
Notsofitmike's Avatar
‘15 rear shocks
hi folks
my wife’s MY15 fit has only about 36k miles on the clock and the rear tires are cupping and are damn near bald . Normally I find that worn shocks are the culprit of the cupping .
My my issue with this is two fold .
1) 36k Miles seems incredibly low for shocks to require replacement . Is this normal for these cars ?
2) I can’t find rear shocks for a MY15 fit to save my life . Rock auto , auto zone , the web site for Monroe , kyb, Gabriel all have no listing ?! Does anyone have a part number for replacements ?
Thanks in in advance fit folks
Old Oct 24, 2017 | 11:07 AM
2Rismo2's Avatar
How's the alignment on the rear? Do you regularly rotate the tires? The rear isn't easily aligned, but there is a shim kit that will allow you to.
If you're willing to go aftermarket, there is Koni STR.T Orange Shocks 8050-1131 for the rear. 8750-1102L, 8750-1102R for the fronts. Several people have changed them out on their GK even though they are meant for GE
Old Oct 24, 2017 | 11:13 AM
Yup rotate them every 6000 miles . Alignment , haven’t checked never seen an alignment cause heavy cupping . I don’t care if the shocks are aftermarket just curious as to why there aren’t any available for the MY 15+ fit.
does that mean that all ge rear shocks will work on the gk’s ?
Old Oct 24, 2017 | 11:15 AM
2Rismo2's Avatar
The rear isn't factory alignable, but at least one user found that their rear-end was out of wack and was able to get it replaced under warranty.
Old Oct 24, 2017 | 12:30 PM
hasdrubal's Avatar
TofuShop was selling a set of GE coilovers that were installed on a GK, so it seems like all GE shocks ought to work. The only thing I would wonder about is the length, I installed Koni orange shocks with a set of lowering springs, and ended up a little lower than I expected. If you're running stock springs it probably won't be an issue.
If you're the type to like a more controlled ride, the Konis work great.
Old Oct 25, 2017 | 02:26 AM
john21031's Avatar
Tire pressure?
If you are rotating every 6K miles, how do you determine that only the rears are bold and have the cupping?
Old Nov 19, 2019 | 12:16 PM
Jim Murphy's Avatar
Following up on this... can someone confirm that the Orange Shocks 8050-1131 are a suitable replacement for the stock rear shocks that came in the 2015 Fit?
Old Nov 19, 2019 | 01:39 PM
evilchargerfan's Avatar
https://www.fitfreak.net/forums/fit-...g-springs.html
works like magic
Old Nov 19, 2019 | 04:18 PM
wasserball's Avatar
Your tires are out of balance. If it is really bad, you should replace the tire(s). If it were caused by shocks, you would have noticed the car less stable.
Blackberry Goose
May 5, 2020 02:50 PM
fit2bking
Apr 29, 2015 06:37 PM
1Gr8GE8
May 4, 2014 12:18 PM
Skimmer
Feb 8, 2008 05:50 PM
Skimmer
Feb 4, 2008 03:46 PM
