Battery Fuse
Old Dec 12, 2018 | 09:16 AM
Craig Cole's Avatar
Battery Fuse
My wife attempted to jump start our 2008 Fit and crossed polarity. I've replaced the battery and it has no power anywhere. I'm trying to find a tutorial about replacing the battery fuse. I see the big 80AMP fuse on the positive battery cable, but I've read there are 2 others. Is this true about there being 3 battery fuses? I can't seem to find any info online or youtube. Thanks
Old Dec 12, 2018 | 10:05 AM
GolNat's Avatar
I would check them all with a volt meter or test light. I’m sure the 80 amp blew but check and replace that and then go from there. You can pull each one and ohm it out as well.
Old May 23, 2025 | 10:55 PM
MissFit58's Avatar
battery fuse
check the Electronic battery sensor in the under the hood fuse box. It is a large brown relay and you have to remove the fuse box from the bottom cover and unplug it from the bottom side of the fuse box.
douglasd5
May 23, 2025 10:49 PM
Arty163
Dec 24, 2018 05:08 AM
pearl
Dec 4, 2014 06:42 PM
MetalHead88
Dec 30, 2011 12:21 PM
minnemike
Oct 16, 2009 11:24 AM
