in need of winter tires and i need some advice =)
Old Dec 2, 2009 | 03:58 AM
tdubl's Avatar
found some deals on winter tires in CL vancouver for my 09 fit, and wondering on some sizes that i can run..
-i have a set of 07 fit sport rims 15 inch.. and i dont know the specs havnt looked at them and they're buried in my little garage..
-should i get a new set of steelies with winters? if so, what size of tires should i be seeking with my 09 fit without wrecking the speedo reading..
--> if im going this route, i know for a fact that 14s work, i was running 14s in my gd3 (r.i.p. along with my winter tires), i also forgot what the tire sizes were.. should i get 14s or 15s.. can ppl list the sizes i would be able to run...
can someone point me into the cheapest and most correct way of searching for winter tires when buying off CL?
thank you!
ps- would 205/70R15 work for my 07 fit rims without any problems?
Old Dec 4, 2009 | 05:54 PM
CPat's Avatar
These links should help you out (note there's some good threads in the shoes section of the main forum)
http://www.carbibles.com/tyre_bible_casestudy.html
For steelies, it's up to you. The sport has alloy wheels and the salt starts to really affect the finish after 3 years or so (canadiandriver forum).
Good luck
oveedrx
Jan 4, 2015 08:07 AM
tdubl
Dec 4, 2009 03:40 AM
ren hoek
Apr 21, 2009 02:00 AM
FitFieFoeFum
Jan 15, 2009 01:08 PM
wongnog
Oct 17, 2008 09:24 PM
